e4od issues?? PLEASE HELP!
Old May 15, 2014 | 08:42 PM
  #31
Mioxy83's Avatar
Mioxy83
Yes but in a weird way! Idk how else to explain it then this P= reverse
R=park
N= drive
D=2
2=1
Ive no clue whats going on anymore
. The first one in line is what my clusters pointer says. The second one is what the trans is really in
Old May 15, 2014 | 08:55 PM
  #32
Mioxy83's Avatar
Mioxy83
And more so it wont even let.me try to select gear 1 if I wanted to the selector arm feels like it bottoms out. Im so confused anymore. Maybe I should just leave it un aligned. Id rather not..
Old May 16, 2014 | 02:01 AM
  #33
Lead Head's Avatar
Lead Head
It's literally impossible for reverse to be before park. It cannot physically happen. If you have your truck in the "R" position right now, you actually have it in neutral. I hope you set your ebrake, or park the truck in a flat area.
Your whole shifter mechanism has slipped down by one notch some how, and you'll need to adjust it.
Old May 16, 2014 | 02:24 AM
  #34
Mioxy83's Avatar
Mioxy83
Hmmm could it have been from tugging on the linkage itself? I didnt think anything of it at the time.. I just pieced it all back for now. Like now my stuff works good. But its back to being unaligned. Cause other wise it jusy refuses to slide on the shaft coming from the trans. How would I go about fixing the shifter now? Maybe if I start there itll help solve.some stupid issue I'm having futher down this process. You see the issue Is I remove.my mlps and align it
I just slip it back on the shaft from the trans however the screw holes dont line up nor the linkage. So
. The only way for me to make it line up is to shift it to tje next In line which is drive and then it slips on perfect and stays aligned. But thats when I get that weird.flip floped shifting
Old May 16, 2014 | 07:21 AM
  #35
subford's Avatar
subford
The transmission itself has to be in "N" (neutral) also before putting the TR sensor on.
Then adjust the TR sensor.
Then put the stalk in "N" (neutral).
Now put the shift arm on the shaft.
Old May 16, 2014 | 07:25 AM
  #36
Mioxy83's Avatar
Mioxy83
Originally Posted by subford
The transmission itself has to be in N also before putting the TR sensor on.
Then put the stalk in N.
Okay and I figured out the weird dash thing tht little wire is stretched out. Ill like zip tie it I guess I already turned the wheel on the adjustment
Chris Petzke
Apr 8, 2018 05:46 PM
trackenator
Oct 16, 2009 05:55 PM
71LTD390
Sep 4, 2008 09:38 PM
Highpockets658
Dec 4, 2003 01:14 PM
