7.3 cutting out
Old May 16, 2014 | 02:16 PM
  #31
madpogue's Avatar
madpogue
Originally Posted by new7.3owner
Idk what code it threw up but it just shut off like i turned it off
Did it shut off when your friend tried to scan it for codes? If so, that's the expected result of attempting to obtain codes using a generic scanner. A generic OBD-II scanner does NOT communicate with our trucks. You need a device that does communicate with the OBS PSD, and you need to obtain the specific code(s); descriptions, as mentioned above, can be misleading, and you could be chasing your tail and spending big money on parts you don't need just going by vague descriptions.
Old May 16, 2014 | 06:43 PM
  #32
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Also I would check the oil level in the HPOP reservoir, it should be 1" or less from the top.
Zach92
Jun 14, 2016 12:53 PM
dumptruck denny
60
Feb 14, 2015 06:53 AM
SPOONMAN1
May 14, 2012 08:37 PM
7.3dieselman
May 9, 2012 08:01 PM
dstad
16
Oct 30, 2009 07:11 AM
