CPS dilemma
Old May 13, 2014 | 10:45 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question CPS dilemma
My truck had some signs that points to think that the CPS es getting wrong.
After some searching I found several CPS # part:
1876736C91
1825899C93
1821720c99
Ford dealer part # F7TZ-12K073-B
I got one from Ford and one for IH with different numbers than de above (see pics below: Ford is black and IH grey). What would you put in the truck?
thanks in advance
Old May 13, 2014 | 11:59 AM
cowmilker08's Avatar
cowmilker08
I don't know, but here's a link to the one I use. No problems with it in 4 years (~50,000 miles).
Ford cam sensor 7.3 Power Stroke Turbo Diesel
Old May 13, 2014 | 12:16 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Unhappy
Thank you sir. WOW ! that's another different number: F4TZ-12K073-C.
Old May 13, 2014 | 04:04 PM
Hussler's Avatar
Hussler
Jose, read this very long but informative old thread.
Everything you wanted to know about the CPS ...
https://www.ford-trucks.com/forums/9...-this-one.html
Old May 13, 2014 | 04:56 PM
Pikachu's Avatar
Pikachu
You managed to get a new, OEM black CPS from a dealership? I'd love to find one at a dealership around here.
Old May 13, 2014 | 07:32 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Thank I just finished that 15 pages thread and Im still a lilttle confused, mostly for the many different # part. I think Im going to see my original (I suppose) CPS and then decide, pretty sure I will go with the black one first. Also the air-gap and shims its a little annoying.
Well I didnt remeber that I bougth one in 2006 (from USA) when I bougth my truck, and now watching my spares I found it, and the IH I just bougth it last week here in Mexico.
Old May 13, 2014 | 07:56 PM
Pikachu's Avatar
Pikachu
Oh. Well, there goes that idea
Old May 14, 2014 | 10:19 PM
oldbird1965's Avatar
oldbird1965
I tried to post this last night Jose but couldn't get on? This is what I'm running.
Old May 15, 2014 | 08:05 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Glenn, thanks, its the same that Phil put in the link of his post.
As I mentioned above Im going to pull out the old one and compare with the new (gray and black) but pretty sure Im going to install the black one and see what happens.
Old May 19, 2014 | 11:15 AM
tjbeggs's Avatar
tjbeggs
use the black, return the gray one, and buy another black one!
Old May 19, 2014 | 11:50 AM
cowmilker08
Hi, Tim. How's it goin?
Old May 19, 2014 | 12:21 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
As I wrote in other thread, glad to see you here.
Thanks for your comment and yes Im insalling the black one, I just pull out the old one and is very similar to the new one, same sizes everywhere; cost me some work, I almost strip (spl?) the bolt and the o-ring was almost melted with the sensor, so to pry it was difficult. This week Im going to install the new one and see how it works.
Old May 19, 2014 | 01:08 PM
glovemeister's Avatar
glovemeister
Have you considered that IH has a degree/spacing tool for cps install? It is designed to make sure it is shimmed properly to get the best readings. I personally believe that this is why some trucks run good with some sensors and bad with others.
Old May 19, 2014 | 01:18 PM
tjbeggs's Avatar
tjbeggs
going well. Thanks! Don't get in here much be every now and then an old thread pulls me back in!
Old May 19, 2014 | 03:40 PM
madpogue's Avatar
madpogue
That sounds interesting. Is this tool available to (and affordable by) mere mortals like us? I'd be curious just to see the procedure on its use. I wonder if this functionality could be programmed into AE, something like - shim the sensor, turn the engine by hand, record the resistance/signal as the reluctor notches pass the sensor, rinse, repeat...
