I've cut your post from the thread you posted in because your problem not only doesn't belong in the forum you posted, but it's not fair to the OP who created the thread and is wanting help for his problem.
But none of that matters anymore because I've created your own thread in the proper forum!
I'll send Mark a heads up letting him know about this thread and hopefully he'll have time to respond and get you some help!
The three codes are all for electrical circuit faults. It would be an amazing coincidence if all three electrical parts failed at the same time. It isn't uncommon for a wiring harness to get three circuits damaged at the same time. Your problem is almost certainly in the wiring.
Check the harness from the connector on the passenger's side of the trans to the PCM AND from the the turbine speed sensor on the top, front of the trams to the PCM.
