Trans woes
Old Oct 28, 2005 | 11:29 PM
watermanh's Avatar
watermanh
Trans woes
Yesterday my trans seemed to be in "safelock" mode. Pulled codes P0750, P0755, P743, P1754. Replaced VSS, checked TPS (working), then cleared all codes. Then went to KOEO, same codes pop up right away. Checked wiring harness and cleaned connectors, started up and everything working-I'm a happy camper. Today I start up and problem is back, I've been through all the connectors and wiring harness again since that seemed to take care of the problem, but this time no luck. Any help would be greatly appreciated, aloha.
Old Oct 29, 2005 | 12:00 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
None of those codes are the VSS or TPS?
The P1754 is the CCS (coast clutch solenoid)....might be the problem since cleaning the CSS connector worked once for you.
Old Oct 29, 2005 | 02:34 AM
watermanh's Avatar
watermanh
No, none of the codes are for the VSS or TPS. I changed the VSS since I had one, expecting the original to eventually go out. The TPS I was able to check operation through the scanner. P1745, that's the one code I didn't have a reference for. Do you know which connector on the tranny this one is?
Old Oct 29, 2005 | 08:51 AM
Kwikkordead's Avatar
Kwikkordead
All those codes the common denominator is the PCM and/or the wiring harness.
Do you live right on the coast where the salt air gets into everything?
Old Oct 29, 2005 | 10:52 AM
watermanh's Avatar
watermanh
I'm not near the coast, but previous owner used the truck for towing a dune buggy so truck did have exposure to sand/mud. As mentioned earlier, I checked wiring harness and connectors and problem did correct itself for a day, if it was PCM problem would that still be possible? Just trying to not think the worst. If it is the PCM, would a reflash be all that is required? Thanks guys for all the input, aloha.
Old Oct 29, 2005 | 01:46 PM
cookie88's Avatar
cookie88
FTE Emeritus
You checked the wiring harness at the tranny? That's where you need to be concentrating your efforts IMO.
Old Oct 29, 2005 | 04:03 PM
watermanh's Avatar
watermanh
I've been cleaning connectors and putting dielectric grease. Checked all but 1 connector at the tranny. Can't get to it, it's at the top/rear side of tranny. Probably the the 1 that's gonna be the problem though. I will try to get at it tomorrow. Hope I can nail this thing, hate to have to take it in, will let you know, aloha.
Old Oct 29, 2005 | 04:15 PM
captchas's Avatar
captchas
Guest
http://www.obd-codes.com/index.php
just to help every one out. heres a link to a site for finding out what code means what.
Old Oct 30, 2005 | 06:21 PM
watermanh's Avatar
watermanh
Nailed it!!!! Thanks all for the help, aloha.
Old Oct 30, 2005 | 10:51 PM
cookie88's Avatar
cookie88
FTE Emeritus
Rock on dude!
