5R110 - Need Electrical Troubleshooting Tips
Problem: Missed 3-5 shifts, seemed to drop to 'neutral' at random.
Codes showed:
P0767 Shift Solenoid D Electrical.
P0766 Shift Solenoid D Performance / Stuck Off.
I replaced the solenoid with a new factory solenoid, replaced filters, fluid flush with fresh ford sp fluid. (Stock solenoid was available locally, and needed the truck up and running or I'd have waited to get a modified gogo solenoid from Empire.) ***
The old solenoid tested fine, so I used it to fix a friends truck that was having the same problem.
*** Problem remained - so replaced wiring harness inside transmission, and seemed to have the problem fixed.
Started the same problem again - less than 500 miles since replacing the harness.
I have more time now - so I'm going to go ahead and swap in the modified gogo solenoid and take the opportunity to verify the electrical connections on the internal harness, as well as add a redundant grounding strap to the transmission case itself to alleviate other potential problems. (This should also have the transmissions ready for more power, since this truck is about to get the EGR 'fixed'
, head studs and tuning - which is why I don't mind 'double checking' my work.) Beyond that - the only thing I can think of is to start troubleshooting the wiring harness on the truck. The connector at the transmission looked perfect, with no scorched pins or obvious loose connections to suggest a problem. (used a digital camera to check for arc-scorched pins)
Is there another common place to find problems in the wiring harness, or am I going to have to break out my wiring diagrams and trace this harness all the way through the truck checking for faults on that circuit?
(tried the search function - without much luck, but it's possible I missed something.)
Thanks in advance for any advice you guys can offer.
Doing my best to be patient. I'd be thrilled if it was as simple as running 1 new wire or adding solder to a badly crimped connector.
Best I can think to do now is reassemble everything with dialectric grease, and borrow the PCM out of a friend's 6.0 to see if the problem persists.
The only thing I haven't figured out is where the small ground lines from the solenoids (yellow/white) are connected to the single larger (yellow/white).
After disassembling the connectors at both ends (which all looked clean) and reassembling packed with dialectric grease, truck seems to be running well. I'll repost if anything changes.
