Frame twist?
Old May 12, 2014 | 03:19 PM
51MercuryM1's Avatar
51MercuryM1
Frame twist?
Just installed a new box on my M-1 and looking at the tailgate alignment with the front box panel, there is a significant drop from the front left corner to the right rear corner. it appears that there is some twist in the frame. The floor is not yet in the box, but will that help straighten things out, or is there something else I need to do to pull them into alignment?
Old May 12, 2014 | 04:17 PM
Giesterfarher™'s Avatar
Giesterfarher™
The easiest way is to shim it to get the right alignment, then cut your blocks to the size you need for each mount. My original frame was twisted 3/4 of an inch higher on the left in the front and 5/8 down on the right rear. Once I got it shimmed, you couldn't tell at all. (I still couldn't live with it though, and opted for a new frame in the long run.)
Old May 12, 2014 | 04:53 PM
51MercuryM1
I thought of shimming the box, but then it just appears to sit crooked when lining up the bottom of the tailgate with the rear end. I was contemplating jacking the one side and then installing an x brace between the frame rails?
Old May 12, 2014 | 05:11 PM
tinman52's Avatar
tinman52
Welder User
Best route would be to un twist it......this is commonly done by a body shop as a frame machine and alignment gauges are needed.
I worked in body shops for years and fixed many sprung and diamonded frames...
Kinda tough to DIY, as the frame needs to be tied down to something solid.
Old May 12, 2014 | 05:21 PM
Olweldinrig's Avatar
Olweldinrig
That is what I was going to say.When I was young I jumped grampas truck and twisted the frame.LOLIt was about about 20 yrs ago but it onlt cost about 50 bucks to fix.Less than an hr time.
Old May 12, 2014 | 05:39 PM
56panelford's Avatar
56panelford
If your shop floor is fairly level I would do some careful measuring on your suspension first to make sure you don't have a sagging spring or hanger binded up before you start shimming your box. I had a 53 parts truck that had more leafs on one side compared to the other likely changed out from another truck when one side broke.
Old May 12, 2014 | 07:43 PM
AXracer's Avatar
AXracer
The Ford frame was a riveted ladder design that was meant to twist rather than tear itself apart The twist you have now may be just due to sagging suspension (springs, shocks, spring eye bushings etc) and/or weight distribution, or lastly collision or abuse damage. I wouldn't be too concerned until you get the suspension in good condition and all the major parts mounted. Don't start adding braces etc It's lasted 60 years without being needed, find out where the problem is and correct it to the way Henry built it.
Old May 12, 2014 | 07:56 PM
Giesterfarher™
I'd go with Axracers suggestion then. Shim it to make it look reasonably square and level, and drive if it if that's your aim for now, or leave it be until you finish the suspension repairs/upgrades, then determine then if your frame is in fact twisted or bent. Then go from there.
Old May 12, 2014 | 08:14 PM
51MercuryM1
Suspension is all new. New springs, shocks, rear end, new hangers, bushings, pins etc.
Old May 12, 2014 | 08:18 PM
56panelford
Are you sure none of it is hung up, are you driving it yet to get the suspension moving? Even tire pressure all around?
Old May 12, 2014 | 11:03 PM
51MercuryM1
Quite a ways from driving, cab isn't mounted yet.
Old May 13, 2014 | 09:35 AM
AXracer's Avatar
AXracer
Frame is way flexible without anything mounted. Put 3 corners on jack stands and add a couple hundred pounds of sandbags to hold it down then jack under the 4th corner, it will go up and down quite a lot! Be sure to support and level the frame front to back and side to side as well as check it for square before you start attaching parts.
Old May 14, 2014 | 01:53 PM
51MercuryM1
Thanks, I will try that.
Stephen67
Jul 2, 2012 11:36 PM
grinnergetter
May 22, 2010 04:36 PM
40Doug
May 21, 2010 12:16 AM
Bender99
Offroad & 4x4
Dec 30, 2009 07:06 PM
do49
Dec 30, 2006 12:16 PM
