water pump issue
Old May 6, 2014 | 10:24 PM
diesldoct's Avatar
diesldoct
water pump issue
I just purchased a new w/p for my 66 300 I6 and the body of the pump is shorter that the original and my pulley is hitting the timing cover...is there 2 different length w/p or is O'Reilly's made in China POS my problem?
Old May 6, 2014 | 11:21 PM
Shadowrider123's Avatar
Shadowrider123
Make sure you didn't get a reverse rotation pump for a newer engine.
Old May 6, 2014 | 11:38 PM
diesldoct's Avatar
diesldoct
I'll check that out...good thing I gave them the year! I searched older post that explain a lot about different pulleys but nothing I could find about the w/p shaft length.
Old May 7, 2014 | 10:48 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There are THREE different 300 water pumps for 1965/74.
D2AZ-8501-A (replaced C5AZ-8501-A) .. 240 & 300 L/D (Light Duty) Waterpump.
1965/72 Galaxie/LTD 240 / 1965/67 Econoline 240 / 1965/70 F100/600 240/300 / 1969/74 Econoline 240/300 / 1971/74 F100/350 240/300.
Old May 7, 2014 | 07:57 PM
diesldoct's Avatar
diesldoct
Finally got the right w/p and with some luck will be taking my 66 f100 4x4 for its first drive tonight! Can't wait!!!
Old May 7, 2014 | 08:33 PM
Tedster9's Avatar
Tedster9
Outstanding! Take some pics, too...
Old May 7, 2014 | 09:54 PM
diesldoct's Avatar
diesldoct
Well looks like Friday now...pulled the water outlet housing to replace the thermostat and its so rusted out the thermostat has no where to sit anymore...one of these days I'll get to spin it around the block!
Old May 7, 2014 | 10:03 PM
diesldoct's Avatar
diesldoct
Pics of my new girl...just picture it with a new ford blue waterpump though, the [IMG][/IMG]first piece of my resto..
Old May 7, 2014 | 10:07 PM
diesldoct's Avatar
diesldoct
[IMG][/IMG][IMG][IMG][/IMG][/IMG][IMG][/IMG]
Old May 7, 2014 | 10:10 PM
diesldoct's Avatar
diesldoct
[IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
Old May 7, 2014 | 10:12 PM
diesldoct's Avatar
diesldoct
Old May 7, 2014 | 10:23 PM
diesldoct's Avatar
diesldoct
I think I stole it for $600, it has power disc brakes and power steering already, offenhauzer intake 600 cfm 4 barrel carb, split exhaust manifold, pertronics electronic ignition and flame thrower coil, the old owner had just put brakes on the rear, it needed cooling system love, I pulled the top tank off the radiator you see in bed, rodded it out, soldered it back together, pressure and flow tested good, just replaced the w/p and now just need a water outlet housing, and a good flush, when i got it home i put a battery in it and it fired right up and sounds good, after i changed the oil filter and oil it idles around 35 psi oil pressure and goes up around 60 at high idle, the old owner said he thought it had a spun rod bearing, if it does it sure don't run like it! he said it had a squeal noise coming from the engine, i found the alt belt loose and a vacuum leak maybe thats what he heard!
jimi
17
Dec 10, 2009 03:12 PM
snwbdrny
Apr 22, 2009 04:58 AM
wickedinhere
Jan 8, 2009 04:32 PM
fourby4
Sep 23, 2008 09:01 PM
63unibody
Jun 11, 2001 04:11 PM
