6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Black smoke
Old May 6, 2014 | 08:04 AM
Vinford's Avatar
Vinford
Black smoke
08 F-450 4x4
Blowing clouds of black smoke when you really put your foot in it.
It used to smoke very little?
Havnt changed anything or done anything to it.
What are some of the usual reasons it might be doing this?
Old May 6, 2014 | 08:53 AM
sxrfun's Avatar
sxrfun
Try cleaning your EBP and MAP sensors.
Old May 7, 2014 | 05:01 AM
bubbasz1's Avatar
bubbasz1
Check to see if the tuner you are running has any particular setting that maybe you can change. The H&S has a setting just for that, I guess some people want to produce thick black clouds of smoke just because, I guess to some degree it might help on the performance end but that's not for me.
Old May 7, 2014 | 02:13 PM
GHeTTo JOe's Avatar
GHeTTo JOe
the h&s setting is called LBF Low Boost Fuel i think it is a 1-5 setting i had mine on 3 (more fuel) and lowered it to 1 (Less Fuel) to try for better fuel economy, yes it smokes more but i did notice a difference in power off the line.
maybe check your air filter?
Old May 8, 2014 | 08:56 PM
Vinford's Avatar
Vinford
I don't have a H+S I have a SCT.
Ill check airfilter , its way to much smoke for me , couldn't even see the last 2 Dodges I passed.
Old May 9, 2014 | 07:59 AM
GHeTTo JOe's Avatar
GHeTTo JOe
maybe pay attention to your boost gauge, is it boosting like normal? possibly not boosting enough?
Old May 9, 2014 | 08:32 AM
Vinford's Avatar
Vinford
How does one know where it should be as it changes when your doing different things?
I watched it coming up a fairly steep hill and it got up to 3500.
eg. passing , towing cruising..........
Old May 14, 2014 | 10:09 PM
GHeTTo JOe's Avatar
GHeTTo JOe
the main thing for your problem of having too much black smoke would be that it is not getting enoughh air, boost. so to make sure you have good air you need to make sure your air filter is not fully plugged of crap, make sure no intercooler boots came off which would cause the truck to not boost very well or at all. if the boost gauge does not move much ever possibly turbo problems.
2006powerstroke90
Jan 17, 2011 07:39 AM
Mat Dope
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Nov 21, 2007 10:46 PM
emmagator
Aug 16, 2007 07:55 AM
Birds 05 F-350
Apr 30, 2006 11:40 AM
wannaburn
51
Oct 24, 2004 06:44 AM
