Best Leveling Kit
Old May 13, 2014 | 07:36 AM
Wasinator's Avatar
Wasinator
I have been doing some research and contacted a few suspension companies in regards to this, if I mount 285/75R18 a lift or a leveling kit is not necessary. Thus, with 34.8" dia tires I will be able to run the stock setup without going through any of the caster or alignment headaches.
Old May 14, 2014 | 06:30 AM
98woody's Avatar
98woody
Should be no problem, the 20" ford rims are running a 34" tire stock
Old May 14, 2014 | 08:55 AM
720Deere's Avatar
720Deere
Most people do the leveling kit to get rid of the dive bombing, low rider front end rather than for tire clearance.
Old May 14, 2014 | 09:22 AM
WABowHunter's Avatar
WABowHunter
I run 285/75/18 Toyo AT2 Extreme and have no clearance issues. I also installed a Hammerhead front bumper with a 12,000 lbs rated Warn winch and do not experience the dreaded front end dive. However, I do have the 6000 lbs rated springs.
Old May 15, 2014 | 01:35 AM
Wasinator's Avatar
Wasinator
I am getting a winch plate gille gaurd combo in the front which I can image is half the weight of your bumper. You said you have 6000lb springs, what are the OE rated for?
Old May 17, 2014 | 10:50 AM
WABowHunter
The springs I have are OE. My truck has the camper package, and 6000 lb rated springs are included with said package - same as snowplow prep. Standard springs are rated 5800 lbs,. I believe.
Old May 17, 2014 | 06:59 PM
720Deere's Avatar
720Deere
Standard diesel front springs are 5600 lbs.
Old May 17, 2014 | 11:37 PM
Wasinator's Avatar
Wasinator
Thanks for the info.
AS350Pilot
Dec 17, 2013 07:12 PM
SniperVision
Apr 11, 2013 09:31 AM
Sarge261
Jun 21, 2010 06:09 PM
gui88ford
2004 - 2008 F150
20
Feb 13, 2009 07:35 PM
spinella
Jul 13, 2008 08:36 PM
