Sponsored by: Real Truck
bigger shocks needed?
Old Jul 13, 2008 | 02:19 PM
spinella's Avatar
spinella
i have a 2000 f350 with a leveling kit the shocks are superlifts and they are leaking.so i want to change them is it necessary to get taller shocks for the front or can i just use stock ones?(i bought the truck with this leveling kit already installed) any good recommandations on shocks?thanks
Old Jul 13, 2008 | 02:33 PM
DCSpecial's Avatar
DCSpecial
What kind and size of leveling kit is it?
I'd go with Bilsteins.....or if the truck is tall enough, Icons.
Old Jul 13, 2008 | 02:57 PM
DaveAK's Avatar
DaveAK
Bought the Bilstiens last year and love'em
Old Jul 13, 2008 | 03:00 PM
DCSpecial's Avatar
DCSpecial
Old Jul 13, 2008 | 03:16 PM
spinella's Avatar
spinella
its a superlifts leveling kit.maybe 1"-2" i don't think it sits too tall.it looks like it has two bigger shackles and longer sway bar ends.the leafs are stock.again i bought the truck like this the shocks look beat up and are leaking.is it safe to assume that the rears will stock because nothing was done back there?(stock blocks and no overload spring.)i don't know if it matters but i am running 35's-thanks again -ed-
Old Jul 13, 2008 | 03:22 PM
DCSpecial's Avatar
DCSpecial
It's probably your stock F-350 block....the shocks I posted above will work. Technically they are a 1.5" lift over F-250 rear blocks
Old Jul 13, 2008 | 04:10 PM
spinella's Avatar
spinella
dcspecial thanks for your replies.i know i have stock blocks in the rear,i just want to make sure i'm understanding you.are you saying i can't run stock size shocks.like ford oem?i'm hoping not to spend a lot of money.i do no off roading.all streat driven and towing.i just assumed because of the front lift that stock height shocks would'nt work.(that they would'nt extend far enough)thanks again.
Old Jul 13, 2008 | 05:23 PM
ReAX's Avatar
ReAX
Up to 2" you can still use the stock spec'd shocks. Most manufactures don't make a shock between stock height and 4-6" lift. Shocks usually have about 2" in either direction of play, so you can use stock shocks for 2" lift or 2" lowering. More than 2", you need to use the next size taller shock.
Also, I love bilstien shocks too.
Old Jul 13, 2008 | 05:45 PM
spinella's Avatar
spinella
thanks again.
Old Jul 13, 2008 | 05:46 PM
DCSpecial's Avatar
DCSpecial
Stock height shocks are normally good for 0-2" of lift as mentioned.
I don't like factory shocks though.
And stock replacement Bilsteins are yellow with blue boots.
Old Jul 13, 2008 | 08:04 PM
rudedogii's Avatar
rudedogii
Icons? Aren't those Bilsteins?
Old Jul 13, 2008 | 08:36 PM
DCSpecial's Avatar
DCSpecial
Nope, never have been.
A number of years back Donahoe Racing used to sell Bilstein shocks with their suspensions. But, they were always labeled as Bilstein 5100s or 7100s.
The Icon Vehicle Dynamics shocks (and back when they were DR sig series) have always been made by Edelbrock, built to Icon's specs with their valving.
