New Truck!!!
Old Dec 17, 2003 | 06:02 PM
  #106
austynn2001's Avatar
austynn2001
so that block wont even work in my truck? i couldnt put a carb on it?
Old Dec 17, 2003 | 06:15 PM
  #107
MW95F250's Avatar
MW95F250
I'd ask somebody over in the 385 Series Forum. They know more than I do and they can tell you for sure, but the last time I looked I thought I had read that.
Old Dec 17, 2003 | 07:28 PM
  #108
bremen242's Avatar
bremen242
You can use it with a carb. the worst thing you'd have to do is put in a plug or two for a knock sensor.
austynn2001:
I wouldn't bore it more than it needs to clean up. The more you bore the less material there is to use in a later rebuild, and I doubt you'd get more than 5HP more by the extra displacement anyways. I'd ask your machine shop, they'll probably recommend .030.
Old Dec 17, 2003 | 07:35 PM
  #109
austynn2001
thanks alot bremen. that guy had me worried.
Old Dec 17, 2003 | 07:49 PM
  #110
bremen242's Avatar
bremen242
I'd still go over and ask them the differences though, that way you aren't surprised, and to make sure you get the right parts.
Old Dec 17, 2003 | 07:57 PM
  #111
austynn2001
yep yep i would be if it wouldnt work
Old Dec 17, 2003 | 07:58 PM
  #112
MW95F250's Avatar
MW95F250
If I were you I'd still ask some of them boys over in the 385 series forum.
Old Feb 28, 2004 | 12:18 PM
  #113
austynn2001
hey, i'm back with another question. i found a dana 60 front end but its out of a deisel and i know it's different but how different? what would i have to change (if anything) and is it worth $350? or should i wait for a good deal on one out of a srw? thanks, Austynn
  #114
austynn2001
whoops sorry, double post
Old Feb 28, 2004 | 12:23 PM
  #115
MW95F250's Avatar
MW95F250
Check the gear ratio to make sure it will match the rear end ratio.
Old Feb 28, 2004 | 12:29 PM
  #116
austynn2001
my rear is 4 10 but i'm not sure about the front end. if it's not, its not a big deal cause i could buy different gears but i just want to know about the axle itself.
Old Feb 28, 2004 | 01:55 PM
  #117
austynn2001
also, i have the ford books that the dealeships mechanics shop worked with that tell EVERYTHING about the truck and it has a section that deciphers everything that is on the door sticker. anyways, under the axle section, there is the number 35. in the book under the number 35 it shows:
Code-----Description---# Capacity-----Ratio
35-------- Dana-----------over 8500-----4.10
i think this is a dana 70. it has 12 bolts on the cover. can anyone confirm this? thanks, Austynn
Old Feb 29, 2004 | 08:45 AM
  #118
bremen242's Avatar
bremen242
It should be a Sterling 10.25. I think the Dana 70s were only on F-350s. If you look on the housing, it will have 60 or 70 stamped if it is a dana.
btw, a diesel Dana 60 will work, but the ratio will probably 3.54. It is easier to get 4.11 if that is what is in the rear. BTW, don't get the DRW Dana 60. You'll have to get new hubs which cost about $300 a side or you have to machine them to fit the SRW.
I was going to post a pic of my sterling, but I looked and the pic was cutoff not showing it
Old Feb 29, 2004 | 08:48 AM
  #119
MW95F250's Avatar
MW95F250
I think he was referring to his front axle.
Old Feb 29, 2004 | 08:52 AM
  #120
bremen242's Avatar
bremen242
He was asking if his rear was a Dana 70, and if a diesel Dana 60 would fit in the front.
and I said a diesel 60 would probably have 3.54 gears. He would probably want to find a SRW f-350, being that it already has the right hubs on the front..
