4.9 vs 5.8 pressure plate differences?
Old May 1, 2014 | 06:32 AM
Motorhead351's Avatar
Motorhead351
Im putting a 5.8 in front of a m5r2.
doing a clutch set search at a local parts store, I notice a clutch disc /pressure plate for a 95 5.8 is $215, 11.5" disc.
or I can get an 11" clutch disc/pressure plate for a 95 4.9 for $85
its also showing the spline diameter to be a hair bit different.
makes me think I should use the 4.9 pressure plate, but im unsure if it will work, im thinking yes, but looking for assurance.
Thanks
Old May 2, 2014 | 10:21 PM
Motorhead351
Guess ill answer my own question, did some digging.
part number for 4.9 11" clutch is the same as the 5.0 11" clutch, 5.0s used the m5r2 transmission like the 4.9, 5.8 and 5.0 are similar other than stroke and deck height, so the clutch should work behind the 5.8.
For those wondering, the flywheel is 5.8 specific but the pressure plate mounting holes on the flywheel, are the same.
1951flatheaddave
19
Feb 8, 2013 05:43 PM
deere55
Dec 18, 2012 08:37 AM
wagonerkl
Nov 30, 2010 09:01 AM
tater_51
Aug 12, 2010 05:22 PM
redf1001962
Apr 24, 2006 08:30 AM
