2003 Excursion Trailer brake lights
Old Apr 30, 2014 | 08:20 PM
Charles Tague's Avatar
Charles Tague
Exclamation 2003 Excursion Trailer brake lights
I am having a problem with my 03 excursion 6.0 . When it is hooked to the car trailer it has all lights except brakes lights on the trailer only. I have checked the relays under the hood and the fuses in the main fuse panel. I took it to Ford and they said it was the switch on the master cylinder but, that checked out fine..... Any ideas?
Old May 1, 2014 | 08:27 PM
kev03's Avatar
kev03
Which connector are you using on the hitch the 4 wire or the round one? I found that the 4 wire one does not get good connections.
Old May 2, 2014 | 04:51 PM
mtnsammy's Avatar
mtnsammy
Grounds and I found the plug behind the bumper was also corroded. Caused me many issues.
Old May 13, 2014 | 09:21 PM
st8yd's Avatar
st8yd
In my o1 there is a fuse under the hood where the relays are.
GeneLaw1
Dec 14, 2011 08:57 AM
makomaker
21
Apr 3, 2010 03:22 PM
makomaker
All Things Towing
23
Feb 24, 2010 09:23 AM
Dave(TX)
1997 - 2003 F150
Aug 31, 2007 12:00 PM
MikeRizz
Jul 20, 2004 08:05 AM
