Sponsored by: Auxito
Trailer lights
Old Aug 30, 2007 | 11:57 AM
Dave(TX)'s Avatar
Dave(TX)
Trailer lights
I hooked up my trailer to my 2000 F-150 via the 4 wire flat connector but got nothing. I bought a circuit tester and no lights are showing up. I looked in the owners manual but can't find which fuse operates the trailer jack. Anyone know a good place to begin tracking down this problem?
Old Aug 31, 2007 | 04:42 AM
streethealer's Avatar
streethealer
I'm pretty sure that it is on a completely different circuit than your tail lights. Try looking in the power dist. box under the hood. I think that there is a relay or a fuse located there for trailer lights. Hope this helps.
Old Aug 31, 2007 | 07:09 AM
projectSHO89's Avatar
projectSHO89
There is a relay for the running lights.
Each brake/turn lamp has it's own fuse, but no individual relay.
Have you lost both brake and running lamps or just one of them?
Steve
Old Aug 31, 2007 | 10:18 AM
Dave(TX)'s Avatar
Dave(TX)
I've lost everything as best I can tell. When I first got the trailer I hooked them up and the brake lites would come on when I turned the headlights on. The lights would completely go out when I hit the brakes and everything seemed to work fine for the blinkers. I hooked up some test wires hoping to try different combinations and I imagine I shorted out the whole system. Will check under hood like suggested for the various fuses. Thanks all.
Old Aug 31, 2007 | 12:00 PM
ranger88a's Avatar
ranger88a
The fuses are under the hood.
