another SAS question (s)
Old Apr 30, 2014 | 07:29 PM
d-day's Avatar
d-day
Was looking to do a SAS on my 85 f250 and ditch the ttb stuff.. yes a Dana 60 would be nice and all but around here people think they have gold and want around 900-1500 for a axle...... no way.. I've searched around and couldn't find a thread not to long ago about putting SD axles in, matching pair of coarse due to the 8x170mm bolt pattern I think. Was looking to swap in 250 SD axles (99-2000's) I'm ok with a Dana 50! This is a light wheeler and tow rig more than anything. Can any of you point me in the right direction? It would be much appreciated, as always thanks guys
Old Apr 30, 2014 | 11:45 PM
hairyboxnoogle's Avatar
hairyboxnoogle
You may have been referring to my thread. Im in the middle of this little project on my 92. What exactly are you wanting to know?
Old May 1, 2014 | 08:12 AM
d-day's Avatar
d-day
Can you put the SD axles in without too many issues. I know the spring mounting is different? Different u joint size ect
Old May 2, 2014 | 12:06 AM
hairyboxnoogle
The spring pads are 3/4" wider, i assume that the u-joints are bigger, but nothing a conversion joint cant fix. I bought a PMF RSK that was designed for use with a SD axle so its all bolt in.
Old May 2, 2014 | 12:25 AM
d-day's Avatar
d-day
Sweet! Did you happen to have a link? I picked up a dana 50 with matching rear rear 10.25 for $200 complete minus one rotor, 3.55 gears and disk on all 4
thohill
Mar 23, 2022 04:37 PM
diesel317
Oct 7, 2012 06:39 PM
jmm
Feb 22, 2010 08:19 AM
rangermike
Apr 7, 2009 10:28 PM
THE KING
Mar 12, 2007 08:11 PM
