Coolant leak
Old May 1, 2014 | 04:51 PM
bduemig's Avatar
bduemig
Coolant leak
I am battling an intermittent leak. It shows up on the crossover pipe, sometimes when it is cold, sometimes when it is hot. It seems to be following the transmission cooler lines and the cable from the battery to the starter.
it seems to be coming from the right side of the block. The motor mount is in the way to see the leak or the trail of the leak.. I can see my block heater and one other freeze plug and they are dry. I thought it may be a hose that only leaks when heated or cooled, but does not seem to be from the hoses. The water pump and weep hole are dry.
The only thing I can't completely see is the thermostat housing. Are there any other possible places to look on the right side of the block?
Old May 1, 2014 | 10:15 PM
Red454sedgwick's Avatar
Red454sedgwick
I bet it's on top the valet drains to the starter side of the truck, The old saying is if you can't find the wet spot use flour.
Old May 2, 2014 | 12:37 AM
bduemig's Avatar
bduemig
Thanks for the info. I will look again in the morning
russ_d_t
Aug 15, 2024 04:38 AM
rodeomanrides
Jan 9, 2014 10:42 AM
tom_delonge2289
Dec 1, 2007 09:03 AM
Will_01_GT
1978 - 1996 Big Bronco
Jul 22, 2005 01:42 PM
TexasGuy001
Feb 25, 2004 09:14 AM
