e4od drop
Old Apr 28, 2014 | 10:40 PM
FF34's Avatar
FF34
e4od drop
Alright so I found out today I need to replace the front seal on my e40d. its in a 93 f350 4x4 with a 7.3, my question is can I drop fix and replace this tranny by myself? also whether drop it myself or get help what else should I do while it is out? Thanks for the help!
Old Apr 28, 2014 | 11:42 PM
85e150's Avatar
85e150
If you are asking, you should get help.
Not sure on the go through, others will chime in.
You know the trans & TC are bolted together in one large, heavy lump, right?
Old Apr 29, 2014 | 01:40 AM
FF34's Avatar
FF34
Nope didn't know they couldn't be taken apart. I haven't done this before guess ill be looking for someone with some equipment!
Old Apr 29, 2014 | 11:47 AM
FF34's Avatar
FF34
So I just talked to a reputable tranny shop and he said 99% of the time there's more problems than just the seal. He said it would fix the problem for a few weeks but the same thing will happen again. Anybody have any input?
I'm loosing fluid from the spout on the bottom of the bell housing on my e4od.
Old Apr 29, 2014 | 01:14 PM
njsvtguy's Avatar
njsvtguy
How does the tranny perform and what condition is the fluid? If either isn't right I would rebuild. If both are good I'd consider just rebuilding the pump which is real easy.
On pulling the unit yourself? I just did a AOD by myself and it's not that bad at all. Used a piece of wood on a floor jack to support the weight.
Old Apr 29, 2014 | 01:54 PM
FF34's Avatar
FF34
The filter and fluid are new. Tranny performs fine but I have a blinking od light once in a while...
Old Apr 29, 2014 | 02:40 PM
85e150's Avatar
85e150
An AOD is a light and fluffy item compared to an E4OD, especially one with a TC bolted to it. FWIW....
The wood on a floor jack will work for a lighter trans but a trans jack attachment or actual trans jack would be in order for an E4OD IMO...
Old Apr 29, 2014 | 03:58 PM
njsvtguy's Avatar
njsvtguy
Lol light and fluffy. I must be getting old. the AOD was at my limits. to the OP I have no experience troubleshooting that trans
NWF150
Jan 6, 2012 11:14 AM
kirbykoon
Nov 18, 2009 05:32 AM
nebraska_e28
1978 - 1996 Big Bronco
Nov 24, 2008 02:54 PM
kdy72601
Apr 19, 2008 09:28 PM
johnnytalent
Mar 8, 2004 12:02 AM
