Completly off topic
Old Apr 27, 2014 | 10:21 PM
86f250XLT-4x4's Avatar
86f250XLT-4x4
Completly off topic
Ok I have been working on a 1973 Pontiac lemans with gto conversion has a 400 in it with an eldebrock 4 barrel and a hei distributor on it for the first time since being put In the car we tried to start it today and after working out all the stupid little issues...
Fuel not getting to carb ( fuel line pinched, mech fuel pump bad)
It will not start!
It's getting fuel!
It's getting spark!
Check the plug wires and they are in the proper order!
It kinda back fires but 99% of the time it's thru the exhaust
Not sure where to start
Engine was rebuilt by someone else but told it ran before being pulled! Distributor was left in the engine and "not messed with"
Old Apr 27, 2014 | 10:40 PM
Macrobb's Avatar
Macrobb
What does it do on ether?
Old Apr 27, 2014 | 10:44 PM
Ford_Six's Avatar
Ford_Six
Sounds like the pattern might be backwards.
Old Apr 27, 2014 | 10:57 PM
86f250XLT-4x4
It doesn't act like it was sprayed at all!
Old Apr 27, 2014 | 11:34 PM
96ExtracabPSD's Avatar
96ExtracabPSD
Try a little gas down the carb? You said no fuel to carb, then said it is getting fuel. Which is it?
Old Apr 27, 2014 | 11:43 PM
hairyboxnoogle's Avatar
hairyboxnoogle
dizzy is 180 out i would say
Old Apr 28, 2014 | 02:08 AM
ozdatman's Avatar
ozdatman
yep, sounds like the dizzy is out
Old Apr 28, 2014 | 07:07 AM
86f250XLT-4x4
It has fuel and spark
Old Apr 28, 2014 | 12:28 PM
Ford_Six's Avatar
Ford_Six
All that's left is timing then. There is a remote possibility the firing order is not stock, in which case you'll have to pull the valve covers and watch the rockers to see what's moving when.
Old Apr 28, 2014 | 05:02 PM
bashby's Avatar
bashby
Make sure the plugs aren't fouled.
Old Apr 28, 2014 | 05:19 PM
86f250XLT-4x4
Checked firing order repeatedly and we put new plugs in it after having starting issues and it still won't start
Old Apr 28, 2014 | 06:44 PM
Red454sedgwick's Avatar
Red454sedgwick
Take the valve covers off and make sure the lifters are working, also where are you getting you firing order and how are you counting the cylinders?
Old Apr 28, 2014 | 10:28 PM
racer30's Avatar
racer30
You need to static time it with the TDC mark and the distributor cap off to number one...Then make sure you have the correct firing order for the 400 engine. If it fires only on one cylinder you have the wrong order. the Pontiac engine had some different firing orders for some of there Engines so keep checking...
Old May 5, 2014 | 08:09 PM
86f250XLT-4x4
Sorry took so long but answer was.static timing needed.set!.. Car is/was running... Engine sat after being rebuilt and only ran for a short period of time headgasket dry rotted and now needs replaced... But thanks for the help
Gryphon1962m
22
Apr 24, 2022 11:27 AM
David Reid
Oct 7, 2017 12:42 PM
civilwarcollector
Dec 20, 2007 11:10 AM
gearshift101
47
Nov 15, 2004 04:28 PM
Blorton
Dec 18, 2001 12:31 AM
