1950 226 Flathead 6 transmission problem. Advice?
I have a 1950 Ford F1 with a 226 Flathead 6 in it. To my knowledge it is the original engine. Anyway, I believe I am having major transmission problems, right now it won't even drive even though 3 days ago I drove 40 miles and didn't hear anything or feel anything. The only issue I noticed is my speedometer stopped working. As I am have mentioned in other posts, I am not mechanically gifted like many of you, so I could have other problems that I am unaware of. But I had a few people look at it (one guy is a GM mechanic), and they think the output shaft has let loose. These guys recommended I find a used transmission. Does anyone have any suggestions for this?
My truck is not a show truck and won't ever be one, I just want to have a truck to drive around in 20-40 miles a week. I am not worried about having original parts in the truck, I just want safe parts in the truck.
Do I need a new/used transmission? If so, any suggestions on where I could find one and about what I would have to pay?
Let me know.
Thanks so much for any you can give.
Brian
Let me know.
Brian
I have never heard of an input shaft breaking. I guess it is possible. I'm a bit confused by your post thought. Does your truck:
a) not drive at all because it won't move from engine power
or
b) not drive because you are afraid to drive it
There are two common causes of a speedometer not working. If that is the only thing wrong, I would un-screw the cable from the back of the speedometer, drive slowly, and see if the cable is turning. This cable can break, particularly if it never gets greased. Speedometers can break, usually from hard old lubricant and built up grime.
or
Start with the basics:
Is the drive shaft (including the u-joints) intact? All the pieces from the tranny the the differential in place?
Are the clutch mechanisms intact? Push the clutch pedal and follow the linkage all the way to the tranny. There should be a transfer of the motion from the pedal to the tranny.
With the engine off, can you move the shift into all the gears?
You don't yet know what the problem is, don't buy any parts until until you do.
DW
DW
Thanks for your posts. Here is some more information that may help.
The truck won't drive at all
The drive shaft and u joints are intact. The yoke is really wobbly, it can move about 1-2 inches so there is a lot of play.
The clutch mechanism is intact.
When the engine is off, you can move the shift in all gears.
Also, when the engine is off it rolls even in gear. Had to put blocks to prevent it from rolling.
When the engine is running and you try to put it in gear it really grinds.
Does that information help?
Any thoughts based on that?
It would help if you put your location in your information that is visible to forum members.
BTW, it is not difficult to remove the top of the transmission, drain the grease, and visually inspect.
Edit: I re read your post and you mention an F1. You're probably not interested in my transmission.
Assuming this is a 3-sp trans, I agree with the above that the output shaft has snapped. There are a couple of grooves in the shaft right behind the rear bearing and speedo gear where it could snap. I can't think of any reason for it to snap unless the driveshaft is the wrong length, or the front U-joint is seized up.
IF you have a 3-sp Light Duty trans, the replacement part would be 1C-7061-A. I'm sure either Van Pelt's or someone on here has a spare used one.
It is a 3 speed on the floor.
There is no resistance when you push in the clutch.
I am in Bloomington, IN so if anyone has parts that could help me, let me know.
How much is an output shaft?
Out of curiosity, what would a new transmission cost for this truck?
Thanks for any help people have been able to give.
Brian
Brian
No clutch pedal resistance suggests damage in the clutch components, which could perhaps mean a disconnect of the engine to trans. However, I wonder about the "wobbly" driveshaft yoke. There should be no up/down movement of the yoke as it fits on the splines of the trans output shaft. I also suspect a broken shaft....BUT that would be pretty rare.
Put your shifter lever in neutral. Then unbolt the shifter housing and lift it straight up. This will allow you yo inspect the upper gears inside. To see any of the lower gears, you will need to drain the oil. Compare the gears to the pics you see (3rd view down) on our website. It may be apparent to see what is happening. Here is that link:
Ford Top Loader Three Speed Transmission Gears
We have repair parts and we also rebuild them.
It sounds to me like you have clutch troubles and transmission troubles. If you clutch is working the gears won't grind like that even if your transmission has broken parts.
Drain then pull the transmission. Mark the position of the pressure plate on the flywheel (in case they are balanced together) then pull the clutch parts. Take the top off the transmission. Then post pictures of everything and we can advise you further.
yellowfish
1983 - 2012 Ranger & B-Series
23
01-07-2009 09:49 PM
Pinchmaster
11-10-2002 07:12 PM
