should this happen
Old Dec 23, 2008 | 03:40 PM
joe f350's Avatar
joe f350
Exclamation should this happen
when i was towing my truck around the block to get it in my drive way when i started the truck for so my freind could use the power steering it was in nurtal the drive shaft started truning rather quick so i killed the truck try agin same thing i end up puting the tcase in nutral them it stoped this dint hapen when i broke my pionon york we wont talk about that what couse case this should this happen when the tranny is in nurtal and not conted to the read end if this post isnt clear i asking should the drive shaft turn when the truck is in nutral
Old Dec 23, 2008 | 03:47 PM
starmilt's Avatar
starmilt
Joe they will do this some but it should not spin fast like it is in gear if it does your pilot bearing is bad this would also make it hard to get in gear when you are idling.
Old Dec 23, 2008 | 03:57 PM
RCrawler's Avatar
RCrawler
There is enough drag in the transmission to cause the output to turn. As Starmilt said, it shouldn't be turning at speed.
Hmm... maybe the cause of your transmission shifting hard...
Jason
Old Dec 23, 2008 | 04:16 PM
ford trans tech's Avatar
ford trans tech
yes the drive shaft will turn at engine speed in neutral with the shaft not connected
all the friction clutches in the trans average about .010 clearence for each clutch plate the fluid that is coating all of the clutches will have sufficient drag to spin the driveshaft
with out it being attached and the colder itis the more drag thats created
you have a normal condition
Old Dec 23, 2008 | 04:25 PM
ford trans tech
and the same also applies for manual transmissions teh gear lube causes enough drag in the syncro,s to do the same
Old Dec 23, 2008 | 05:08 PM
starmilt's Avatar
starmilt
Ford tech it is manual And he has been having trouble with his tranny.
Where ya been.
Old Dec 23, 2008 | 05:23 PM
AndysFords's Avatar
AndysFords
Sounds like an old Massey Fergueson Tractor, the PTO always would turn even when off, but if you put your hand on it it would stop.
Old Dec 23, 2008 | 05:26 PM
starmilt's Avatar
starmilt
Yea they will always turn but no power.
Old Dec 23, 2008 | 08:11 PM
joe f350's Avatar
joe f350
this is my bet with what wrong with my tranny
Old Dec 23, 2008 | 08:22 PM
starmilt's Avatar
starmilt
Oil or grease on your clutch disc will cause them to not release properly too.
Old Dec 23, 2008 | 08:29 PM
joe f350's Avatar
joe f350
ether way i have to rip out the tranny
Old Dec 24, 2008 | 12:54 AM
ford trans tech
starmilt , i have been busy with a building project and a few repair jobs
Old Dec 24, 2008 | 01:07 AM
starmilt's Avatar
starmilt
OK we were just missing ya.
Old Dec 24, 2008 | 03:31 PM
joe f350's Avatar
joe f350
any one want to help we rip out my tranny
Old Dec 24, 2008 | 03:33 PM
starmilt's Avatar
starmilt
You still got that mean mom around.
