351M header help with AC
Old Apr 24, 2014 | 06:45 PM
1979 300i6's Avatar
1979 300i6
What is the best way to install the header on the passenger side? I'm thinking I am going to have to remove the fan box for the AC, my next question is how do you remove this ?
Old Apr 24, 2014 | 08:01 PM
blue04.5's Avatar
blue04.5
Do you have the headers in hand? Can you pull the starter, jack the motor up, drop the header in, bolt up the starter, and then mount the header?
Old Apr 24, 2014 | 08:09 PM
1979 300i6's Avatar
1979 300i6
Yes I've already put the drivers side on, so I need to unbolt the motor from booth mounts and jack it up?
Old Apr 24, 2014 | 08:19 PM
blue04.5's Avatar
blue04.5
Yes I would try that. Had to do that to get mine in my sig truck. may have to loosen or remove transmission mount to get enough flex as well. I don't think I had to remove my starter, but it should give you more room. I have a small block ford though.
Old Apr 24, 2014 | 08:20 PM
1979 300i6's Avatar
1979 300i6
Wow sounds like I'm in for a job l
Old Apr 24, 2014 | 10:20 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes drop the starter, maybe jack the motor, that outer box just not come off as easy as you want.
Looks like you are not using the heater core or a/c anyway, remove it and put in a none a/c box. Heater box only fits inside cab. And make the hole smaller and then easier to drop them headers in.
Here is what is in that side of the box.
Old Apr 24, 2014 | 10:27 PM
1979 300i6's Avatar
1979 300i6
Yes drop the starter, maybe jack the motor, that outer box just not come off as easy as you want. Looks like you are not using the heater core or a/c anyway, remove it and put in a none a/c box. Heater box only fits inside cab. And make the hole smaller and then easier to drop them headers in. Here is what is in that side of the box.
We'll only reason the heater lines are disconnected is because I was Repairing a leak in the lines and I would like to get the AC a going again so I think I'll try to keep it all there for the time being but if I decide that it's to much trouble I will definitely consider it thanks for the info.
mater73
24
Oct 17, 2010 09:34 PM
deereman2
Mar 24, 2008 01:59 AM
Edge Motorsport
Feb 28, 2005 03:11 PM
TheMachfather
Jun 13, 2004 09:34 AM
Sedric
Jan 22, 2002 12:21 PM
