removing starter
Old Oct 2, 2010 | 11:11 AM
mater73's Avatar
mater73
removing starter
trying to remove a starter from a 73 f 350. it has headers and i am having truouble getting it out from around the pipes. any tips?
Old Oct 2, 2010 | 11:20 AM
79 f350ts's Avatar
79 f350ts
youll probably have to remove the headers, maybe just loosen them if your lucky. one of the small hassles of running headers
Old Oct 2, 2010 | 11:41 AM
Kalve's Avatar
Kalve
then on the starter you have 3 bolts on it you should be fine with the headers out of the way.
Old Oct 2, 2010 | 12:37 PM
mater73's Avatar
mater73
thanks ill try that and see what happens
Old Oct 2, 2010 | 12:55 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
If it is a 360/390 (you aren't saying what engine you have) you'll need to remove the header bolts and move the headers over and drop the starter out the bottom.
Install the new starter thru the frame rail/ inner fender and then re-install the header.
Josh
Old Oct 2, 2010 | 06:34 PM
mater73's Avatar
mater73
ok i worked on removing the header and got all the bolts but 2. the bolts that are giving me problems is the second one in on the top and it is stripped and the other is the fourth one in on the bottom and the corners were rounded. thinking that im going to end up having to cut the heads of the bolts off and hope that im able to pull the header off and use vice grips to pull the rest of the bolt out. the moter is a 360. let me know what yall think and if yall have any other tips or ideas. who knew that when i started at 9 this morning to change out a starter that it would end up being a pain in the ***.
Old Oct 2, 2010 | 08:06 PM
Bullitt390's Avatar
Bullitt390
Bummer about the bolts, but getting the starter out is what it is. Detach the header and unbolt the starter.
If the starter is getting replaced just let it fall out.
Are you 100% sure the starter needs replaced?
Josh
Old Oct 2, 2010 | 08:48 PM
mater73's Avatar
mater73
yeah earler today it started smoking and making some really bad sounds. it also kept running with the engine off
Old Oct 2, 2010 | 08:57 PM
mater73's Avatar
mater73
but i have decided that im going to track down whoever thought that it was a good idea to take the orginal exhaulst off and put the headers on and kick their *** because it makes a easy job hard and time consuming. baught the truck a little over a week ago and did not expect to have to do so much work to it. so far ive had to replace the choke cable, battery, starter solenoid, neg battery wire, solenoid wire, and now the starter, manifold bolts and gasket. i hope nothing else goes wrong for a while.
Old Oct 2, 2010 | 11:07 PM
Bullitt390's Avatar
Bullitt390
A continuously running starter is a symptom of a bad solenoid or ignition switch.
Josh
Old Oct 3, 2010 | 10:14 AM
mater73's Avatar
mater73
changed out the solenoid 2 days ago so i dont think that its that. is there a way to tell if the ignition switch is bad?
Old Oct 3, 2010 | 10:16 AM
Bullitt390's Avatar
Bullitt390
The easy test is next time the starter stays running is to disconnect the "S" post wire at the solenoid.
If the starter stops it's the ignition switch. if the starter remains running it is the solenoid.
Josh
Old Oct 3, 2010 | 10:35 AM
mater73's Avatar
mater73
ok well since im all ready about half way through with changing out the starter ill still put the new one in and then see if it keeps doing the same thing then replace the ignition switch.
Old Oct 3, 2010 | 03:35 PM
mater73's Avatar
mater73
good news thanks to irwin bolt grips and pb blaster the header is finally off and the starter is out. later this week the list of things to do is replace the starter, 2 gaskets, 8 manifold bolts, and check the new solenoid and ignition switch if problem continues.
Old Oct 3, 2010 | 03:50 PM
79 f350ts's Avatar
79 f350ts
let us know how it goes and good luck
