No Start after HG's
Old Apr 22, 2014 | 07:21 PM
89formula's Avatar
89formula
No Start after HG's
just finished doing HG and injectors, now the truck won't start. its a 2005 EX have checked everything oil system is tight but it is not producing any pressure build-up, oil is in the rails as verified by removing the bleed plug on driver side and ICP on pass side. it has the updated standpipes and dummy plugs, at wits end and not sure where to check next
FICM 48 constant
IPR goes from ~45 to 77
Old Apr 22, 2014 | 07:23 PM
Rusty Axlerod's Avatar
Rusty Axlerod
What is cranking ICP and rpm? How much have you cranked on it? Did you pre fill HPO resivour?
Old Apr 22, 2014 | 07:39 PM
89formula's Avatar
89formula
highest ICP gets is 10 not sure on the rpm but it is more than enough, alot, yes and even went back into it to make sure that it was pumping oil and it is and the rails are full
Old Apr 22, 2014 | 07:59 PM
BLADE35's Avatar
BLADE35
Post these following sensor at KOEO and Cranking
ICP
ICPV
IPR%
RPM Need 150rpm+ to start
Old Apr 22, 2014 | 08:05 PM
89formula's Avatar
89formula
ICP 0 at KOEO up to 10 when cranking
ICPV 0.23
IPR 44 at KOEO then 77 when cranking
rpm is well above 150
FICM 48 constant
Old Apr 22, 2014 | 08:12 PM
mustang_309's Avatar
mustang_309
ICPV 0.23
FICM 48 constant
IPR should be 14 at KOEO and 85 while cranking with low ICP pressure.
Old Apr 22, 2014 | 09:15 PM
78fordman's Avatar
78fordman
Is there a tuner on it? What is your fpw while cranking?
Sent from my leash using IB AutoGroup
Old Apr 23, 2014 | 10:51 AM
89formula's Avatar
89formula
no tuner and what is fpw
Old Apr 23, 2014 | 11:15 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Fuel Pulse Width is an easy way to check cam/crank and FICM/PCM synch
Josh
Old Apr 23, 2014 | 11:24 AM
Rusty Axlerod
Josh, I can't find my reference for it but isn't 77 a common number for a failed IPR? (I meant ICP)
Old Apr 23, 2014 | 12:18 PM
Bullitt390's Avatar
Bullitt390
I think that ended up being a weird coincidence a couple of different times IIRC.
But I believe you're on the right track... The IPR is likely clogged or damaged.
Josh
Old Apr 24, 2014 | 11:50 AM
89formula's Avatar
89formula
ended up replacing the ipr and had several hpo leaks on pass side 2 from injectors and the standpipe
good2eat
Jan 13, 2017 11:34 PM
spongecop
15
Sep 9, 2016 12:33 PM
Gregad
Mar 24, 2015 10:12 AM
roushcm
Feb 14, 2010 12:07 PM
justme1
Jun 17, 2009 07:23 AM
