hard start
Old Jun 16, 2009 | 11:17 PM
justme1's Avatar
justme1
hard start
2002 f-250 7.3 p.s.4x4 xlt auto O.D.
580,000 km aprox.250,000 miles
Miles are 95% pulling miles 15/40 conventional oil, same oil all the time.Regular maintanance[fluids&filters] A small problem started with the truck last week,it requires much longer cranking to start than normal sometimes it will stall after It starts running.I've been told maybe the high pressure oil pump,any thoughts would be appreciated. Thanks
Old Jun 17, 2009 | 05:48 AM
just another truck's Avatar
just another truck
What are the temp's where you are at, have you checked the oil level in the HPOP resovoir?
Old Jun 17, 2009 | 06:06 AM
F350-6's Avatar
F350-6
Any drop in fuel economy lately? Did you start using any oil? Possible injector o-ring issue.
Old Jun 17, 2009 | 07:23 AM
dmueller71's Avatar
dmueller71
My HPOP seems to drain over night. It got better when I replaced the injector o-rings. But It still happens sometimes. When It doesn't start right up, pull the plug from the top of the HPOP and stick a small screwdriver or something you can't drop inside, as a dipstick. It will probably come up dry. I used to carry a squirt bottle full of oil to refill the resevoir, and it will start right up.
mcfarmer
Modular V8 (4.6L, 5.4L)
Feb 22, 2014 11:07 PM
wrdabney
23
Feb 6, 2011 06:14 PM
SPEC
Oil & Lubrication
May 6, 2009 07:11 AM
cattlerancher
Dec 15, 2007 03:01 AM
harris2108
Feb 27, 2007 06:09 AM
