speedometer
Old Apr 22, 2014 | 07:00 PM
jeep_guy48's Avatar
jeep_guy48
speedometer
Just wondering if a speedo out of a gasser will work in are trucks if I switch out the face trim so that the tach is right?
Old Apr 23, 2014 | 07:33 AM
DIYMechanic's Avatar
DIYMechanic
The speedo and tach are actually two separate units and can be swapped independent of each other. And to answer your question more directly, yes I believe the speedo is interchangeable with the gassers, but unless you swap over the PSOM as well (it's a module on the back of the speedo) the mileage will display whatever was on the gasser.
Old Apr 23, 2014 | 09:47 AM
jeep_guy48's Avatar
jeep_guy48
I believe that it is all one piece and cause of that the entire cluster has to be changed unlike the older models.
Old Apr 23, 2014 | 10:07 AM
DIYMechanic
Are you sure about that? I was almost sure that the tach, speedo, and other gauges were in 4 separate pieces.
Old Apr 23, 2014 | 10:17 AM
DIYMechanic
This makes it look like a separate unit:
https://www.ford-trucks.com/forums/1...the-truck.html
Old Apr 23, 2014 | 10:21 AM
DIYMechanic
Here's another one, albeit this one is the gasser gauges, but it shows the PSOM removal as well.
https://www.ford-trucks.com/forums/1...ing-issue.html
Old Apr 23, 2014 | 12:05 PM
jeep_guy48's Avatar
jeep_guy48
I just assumed it was one unit when I saw the mapping on the back.
Old Apr 23, 2014 | 12:11 PM
madpogue's Avatar
madpogue
That's just the circuit board on the back. The gauge heads plug into the board through the "base" of the cluster. Take off the lens and it will be clear how the various segments can be separately removed. Lightning speedometer (140 MPH?) is a favorite mod.
tomkara
Dec 20, 2010 12:40 PM
wreckinball
Oct 20, 2010 10:56 PM
Stephenhutto
1997 - 2003 F150
Dec 20, 2009 04:33 PM
ranger982
1983 - 2012 Ranger & B-Series
Jul 22, 2009 04:06 PM
FreeAgentRider6
2004 - 2008 F150
Dec 29, 2003 07:57 AM
