Odometer
Old Dec 20, 2010 | 11:54 AM
tomkara's Avatar
tomkara
Odometer
I swapped the gauge cluster in my 93 F250 for one that has a tach now the odometer reads 149,000+ . My truck only has 58,000 on it , I thought the mileage would be stored on the ECU or some memory board. is it stored in the speedo/odometer?
Has anyone been through this?
Old Dec 20, 2010 | 11:58 AM
88dually's Avatar
88dually
you have to swap ur old speedo into new cluster
Old Dec 20, 2010 | 12:03 PM
Onus's Avatar
Onus
I found this out on my 91' Mind you different interior and its not electronic. But the tach speedo, and the non tach speedo are not the same. The tabs are different. I'm sure its the same with the newer ones as well.
Old Dec 20, 2010 | 12:33 PM
raptor1971's Avatar
raptor1971
Here is how to swap them out:
Installing An OEM Tachometer In A 1992-1996 F-150 Or Bronco .: Articles
Old Dec 20, 2010 | 12:38 PM
tomkara's Avatar
tomkara
odometer
Ok, thanks
Now lets see if i can take the cluster apart with out breaking it,
Old Dec 20, 2010 | 12:40 PM
tomkara's Avatar
tomkara
Man thats great
thanks alot !!
