speedo and tach
Old Oct 19, 2010 | 09:40 PM
wreckinball's Avatar
wreckinball
speedo and tach
Guys, the GPS works well but i need to get some kind of mile marker and speedo on this beast. I have the LS rear with the VSS and i do have the hanging wires with connector from the IP housing, but how can i hook in tach or speedo? I also have the xfer case electrical plugin. I know i can get the tach sensor that straps around the alternator but what about speedo? Just get a whole setup or?
Old Oct 19, 2010 | 10:13 PM
David85's Avatar
David85
What year interior do you have in the truck?
92 and up needs the VSS signal.
92 down needs a cable from the transfercase.
I can't remember if the speedometer signal on the 92 trucks has to go through the PCM first. I don't think so because some trucks of that era had the IDI and 5 speed transmission - which would not need a computer anywhere in the truck.
Best starting point would probably be to get a manual that has good wiring diagrams and try to reverse engineer that. If nothing else, you will need that for reference if you opt to get a complete wiring harness out of a wrecker instead.
Old Oct 19, 2010 | 10:56 PM
wreckinball
well i have the 1994 f150 interior haha. I am trying to find a cluster from a 1993 or so so that i can just bolt it in but the more i think about it, i want all of the gauges to be mostly in the pillar pod and then i can just mount whatever i want in the cluster area. The more i say cluster, the more i laugh. hahaha it really is one. If i can nail this down i will be solid. i maybe get two drips of oil now, so i am not hot to do the crossmember mod so i can save for that one over time, but i really want a tach and speedo. I am thinking that the rear end is a 1992 the more i look at it but who knows? literally! it seems to be identical to my friends and he has the VSS on the LS rear end, just like mine does. Since i have the VSS on the rearend, is it the newer?
Old Oct 19, 2010 | 11:18 PM
David85's Avatar
David85
The VSS seems to be universal from 1987 and up even though 1992 and up was when ford introduced the electronic speedometer. I remember Starmilt saying he swapped on across that transition year without any problems so you should be good to go using what you have to drive a 1992 and up speedometer......
of course, now you have to get all difficult and pine about making something different with pillar pods and what not.....why do I even bother......
LMAO
Old Oct 19, 2010 | 11:31 PM
wreckinball
because its fun! hahaha. Itll work out in the end. I really do wish i could just swap out a whole cluster.....anyone donors out there? All i can find is the pre 1993 styles. ah well, ill get there one day!! with your help of course! lol!
Old Oct 19, 2010 | 11:57 PM
David85's Avatar
David85
The speedometer can be out of anything 92 and up, but for the tach, it would be best to find a donor diesel truck to rip it from. Wrecking yards should be able to find something especially if they have a network like BC auto wrecking or comox valley auto recycling both have. Of course, they will probably want some blood and an organ as a down payment.....
Other then that, just keep an eye out on craigslist for trucks being parted out.
One of the local wreckers here usually wants $75 for a complete cluster assembly an he is easily the lowest price around. I don't think he has a diesel ford 92 and up though.
Funny thing is princess auto had a surplus sale on diesel tachs for that era of truck a couple years ago. Was strange seeing that in the flier but what the heck could I do with them? Thinking back I guess I could have bought them off for safe keeping since these parts will get rare as time goes on. Oh well...
Old Oct 20, 2010 | 09:05 PM
wreckinball
ive had an order in at two yards for a cluster for three months and nothing. starting to get frustrated too because i have seen three trucks that match the specs i set and not a phone call but when i check the yard, the dash is in pieces. He says oh yeah it came like that. Friggin bull**** ******* so i stopped asking and told everyone i know to ignore him.
Old Oct 20, 2010 | 10:22 PM
eraser5's Avatar
eraser5
My Garmin 255W logs mileage. It has a dashboard feature the has speedo, odometer, time moving, time stopped and other stuff.
Speedhut has full GPS speedometers that have and analog needle, odometer and a lot of other info. 3" and 4", white face or black face.
Just some options
Old Oct 20, 2010 | 10:56 PM
wreckinball
WOW, the customizing options are insane!! thanks bro!! I appreciate it, so much for dealing with more sensors and wiring! GPS baby!! haha
