Dash help
Old Apr 21, 2014 | 04:12 PM
creedua's Avatar
creedua
Dash help
Ive found several ways to fix the dash on the old trucks but no way on how to remove it. Can someone post a quick how to?
Old Apr 21, 2014 | 07:19 PM
Gary Lewis's Avatar
Gary Lewis
I assume you mean the dash cover and not the whole dash. I don't have pictures nor can I point to a how-to. But, here's how to from my memory:
  1. Pull the headlight switch **** off. I believe there's a how-to on that, but there are two ways:
    1. There's a notch in the back of the **** with a tab that can be pulled rearward into the notch, releasing the ****.
    2. There's a button on the headlight switch itself. Contort yourself to get to the button and push it while pulling the **** out.
  2. Pull the wiper switch **** off using the #1 way from the headlight switch.
  3. Pull the one screw that holds the black wrap piece on the steering column and remove it by spreading it open.
  4. Pull the two screws that hold the trim piece below the steering column and remove it.
  5. Pull the few screws along the front edge of the dash cover
  6. Pull the screws in the defroster ducts up by the windshield
  7. Remove the cover
Old Apr 22, 2014 | 11:46 AM
1986F150six's Avatar
1986F150six
Gary,
The dash pad can be removed by just using step #5 and #6.
David
Old Apr 22, 2014 | 12:16 PM
Gary Lewis's Avatar
Gary Lewis
Oh, you are right! Duh! I was thinking of the instrument bezel AND the dash cover. (Why do I always make things harder than they should be!?!? )
Thanks for catching that, David.
Niwrek
Jan 16, 2016 11:18 AM
LRSTony
Oct 9, 2010 01:42 PM
bowdog
1997 - 2003 F150
Mar 18, 2010 07:31 PM
zedx
Jan 30, 2004 08:28 AM
DeezilDennis
Dec 15, 2001 01:11 PM
