Heads Up RECALL 93 F250 7.3 IDI
Just got a safety recall notice in the mail from ford.
Safety Recall 09S09-Speed Control Deactivation Switch Fire
http://www.phila.gov/fleet/Warranty%...ll%2009S09.pdf
Check your vehicle here
Recall Notices| Ford, Lincoln & Mercury Owners | Official Ford Owner Site
I heard about this recall a year or so ago, and a few incidents here and there (mainly people with F150s, some were saved in time but others burned to the ground and were scrapped.) but it was never quite clear. Some people on other forums said it only affected the gas engines, but god knows how true that was and I don't want to risk it either. When I get my truck, that is another thing I will do. The last thing I would want is my truck burning to the ground over something as simple and preventable as this.
Thanks for the heads up though!
This recall came out in 2005, and it effects ALL of these trucks, f150-super duty, all engine types, the only ones that it doesn't effect are trucks that never had cruise to begin with.
The problem is the switch can start leaking and it's fed from the same 15A fuse that's used for the brake lights, so its always hot. When it leaks, it can light the brake fluid on fire and right above it is the hood insulation, you can see where this is going.
So Ford's fix is to put a intermediate harness between the switch and the factory wiring that fuses BOTH wires with 2A fuses, so now when the switch has an issue it doesn't have to try and blow a 15A fuse (which it can't) just a 2A.
Just some extra food for thought.
My 1988 uses a vacuum-dump switch, and (possibly) the brake-light switch to the same effect.
It is only for the electronic cruise control vehicles, it came out in the obs trucks so anyone with a brick or bullnose does have to worry.
Cruise Control: All Technical Service Bulletins Recall 05V388000: Cruise Control Switch Replacement
MAKE/MODELS: MODEL/BUILD YEARS:
Ford/Bronco 1994-1996
Ford/Expedition 1997-2002
Ford/F150 1994-2002
Ford/F250 1994-1999
Lincoln/Blackwood 2002
Lincoln/Navigator 1998-2002
MANUFACTURER: Ford Motor Company
NHTSA CAMPAIGN ID NUMBER: 05V388000 MFG'S REPORT DATE: September 07, 2005
COMPONENT: Vehicle Speed Control
POTENTIAL NUMBER OF UNITS AFFECTED: 3800000
SUMMARY: On certain pickup trucks and sport utility vehicles equipped with speed control, the speed control deactivation switch may overheat, smoke, or burn.
CONSEQUENCE: A fire at the switch could occur.
REMEDY: As an interim repair, owners will be instructed to return their vehicles to their dealers to have the speed control deactivation switch disconnected. As soon as replacement parts are available (expected mid-October 2005), owners will be instructed to return to the dealers for installation of a fused wiring harness. The interim owner notification is expected to begin during the week of September 12, 2005. Owners should contact Ford AT 1-800-392-3673.
NOTES: Ford recall No. 05S28. Customers can also contact The National Highway Traffic Safety Administration's Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to Home | Safercar -- National Highway Traffic Safety Administration (NHTSA).
Ford/F150 1994-2002
Ford/F250 1994-1999
Ford/F150 1994-2002
Ford/F250 1994-1999
Ford/F150 1994-2002
Ford/F250 1994-1999
If you have an electrical sensor on the end of the brake master cyl bore, your truck originally had the faulty switch. if you only have an electric plug under the reservoir, your truck did not come with the faulty switch. My 1993 F350 diesel also had the faulty switch when new. They switched to this speed control system in either 92 or 93, im not sure which.
bballcrf
04-28-2017 12:15 PM
