Filter Minder Removal
Old Apr 19, 2014 | 02:30 PM
Pikachu's Avatar
Pikachu
Is there an easy way to remove the filter minder, short of cutting or breaking the filter housing where it's mounted? I want to relocate it into the metal exhaust elbow I'm now using, so I'd really prefer to get it and the grommet out without destroying it.
Old Apr 19, 2014 | 02:52 PM
nlemerise's Avatar
nlemerise
Mine was just mounted through a rubber grommet...just pulled and twisted at the same time and it came right out.
Old Apr 19, 2014 | 03:01 PM
Pikachu's Avatar
Pikachu
I tried that already. I twisted and pulled to the point I thought I was going to snap it off. At least I can be pretty sure it wasn't letting any dust past it. The stock filter box was letting enough through without any help, lol. The only reason I don't want to cut the housing is so I can be sure what size hole to drill for the grommet, but if I have to cut it, I guess I have to cut it.
Old Apr 19, 2014 | 03:37 PM
Pikachu's Avatar
Pikachu
Meh. Dremel tool + RotoZip bit = Problem Solved. I'm just glad to finally be rid of that stock air filter box. It was a pure, unadulterated piece of crap.
Old Apr 20, 2014 | 02:00 PM
Bonanza35's Avatar
Bonanza35
I'm surprised it still works. Mine took a dump years ago. Same e99. Mitt of been able to spray WD on it to get it out.
Old Apr 20, 2014 | 02:06 PM
Pikachu's Avatar
Pikachu
Well, that's water under the bridge at this point, lol. Now I'm not sure if I'm going to use it or not. I may just get an actual restriction gauge at some point in the future. A little bit of Simple Green cleaned it up just like new though
Restlesswildman
Jun 16, 2015 02:37 PM
V97F350
18
Apr 1, 2010 12:04 PM
RUSTANG67
Feb 12, 2009 09:25 AM
riley42204
13
Oct 24, 2005 07:55 PM
1fastroadking
Oct 10, 2005 10:26 AM
