Engine overheating
Old Apr 13, 2014 | 06:35 PM
1979 300i6's Avatar
1979 300i6
Engine overheating
I've got a 351M in a 79 f150 that I picked up cheap which was supposedly rebuilt and set for a about a year without ever being fired up at all not even after it was rebuilt, i put some oil with break in oil additives and water in it and hooked up everything and started it and it took right off surprisingly, the engine ran fine, I ran it without the rad cap on to let any air out, but after about 5 minutes it began to boil out of the neck of the rad and the gage was at the mark before "H". Next I took the thermostat out to see if it was faulty but I had the same results just it took longer for it to overheat. I used a Multimeter with a Fahrenheit water temperature checker or what ever it's called, and sure enough the water was around 230°F. I also made the mistake of shutting the engine off with the cap off and it shot a geyser as high as the hood with hot water. Any thoughts on what this could be?
Old Apr 13, 2014 | 09:04 PM
bucks77ford's Avatar
bucks77ford
Wonder what the condition of the water pump is? If it sat, it possible the fins on the pump rusted out and it's not pumping water.
Old Apr 13, 2014 | 09:05 PM
Blue and White's Avatar
Blue and White
Normally it should bleed out and run OK in a few minutes... especially with the stat out.
It sounds like water is not circulating. I'd check the radiator first. Look inside the filler neck at the tubes you can see. Are they crusty and blocked? How about the belt... also is the WP turning OK? There are other possibilities but I'd check those first.
Old Apr 13, 2014 | 09:09 PM
1979 300i6's Avatar
1979 300i6
Yeah I'll definitely check it all out but if the water was not circulating would it get hot like it is? And I forgot to mention the heater was working
Old Apr 14, 2014 | 05:07 AM
User 71024's Avatar
User 71024
With the thermostat out of the engine if you look in the rad cap, the water should be rushing by even at idle. If this is not the case then either the water pump is not pumping or the radiator is clogged.
If it's been sitting don't discount a critter building a nest someplace.
Also make sure it's not running too fast, let it idle while your warming it up.
If you do have good flow past the cap. it could be a fan problem, fan clutch bad?
Old Apr 14, 2014 | 07:09 AM
buttwheat's Avatar
buttwheat
Read this thread it may help. A 351m must have a thermostat in it as it closes a bypass water jacket when it opens.
Old Apr 14, 2014 | 08:56 PM
Blue and White
I would add that the T stat for the 351M/400 is a bit unique with that feature. It was special order at my local AZ. I have seen a few posts where a generic "in stock" T stat was used with bad results. With care by the parts guy/gal "make, model, engine and year" should do it.
Old Apr 14, 2014 | 08:57 PM
1979 300i6's Avatar
1979 300i6
We'll thanks for all the replies, and that is interesting to hear about the thermostats I will definitely give it a shot
Old Apr 18, 2014 | 07:31 PM
1979 300i6's Avatar
1979 300i6
I've also noticed that the radiator in this truck is the same size that my 300i6 and 302 use, and my buddy's 78 with a 400 has a much bigger rad, could this be a issue?
49f3dls
58
Aug 27, 2017 09:16 PM
forgedbyfire
26
May 1, 2011 09:14 PM
Benaghetto
1983 - 2012 Ranger & B-Series
Mar 30, 2007 04:01 PM
TopNotchCC
Jun 29, 2005 03:04 AM
gunnabebad
29
May 1, 2004 10:55 PM
