Question on engine swap...
Old Apr 18, 2014 | 12:52 AM
C-AREVALO's Avatar
C-AREVALO
Alright guys I got a sweet deal on a parts truck I bought. I got some questions first my truck is a 1979 f 100 with a 351-400m I wanted to swap the engine out for a 351w that I got from the parts truck. What kind of motor mounts would I need as far as year goes. The other question will a 1995 5 speed tranny work on my 1979. If it does not then what kind of aod should I use. Thanks in advance...
Old Apr 18, 2014 | 09:15 AM
C-AREVALO's Avatar
C-AREVALO
Anyone. ..
Old Apr 18, 2014 | 10:46 AM
HIO Silver's Avatar
HIO Silver
Need more info I think.... what year is the parts truck?
SBF mounts will fit the 351W.. just make sure it's a 351W.
An AOD has four (forward) gears..... are you sure you know what you wanna do? Are you looking for a 5-speed automatic?
For a 5-speed manual trans, a T-5z is compatible but I think it's a bit weak-kneed for a truck. A better option is a Tremec TKO... that's a manual trans.
Old Apr 18, 2014 | 05:17 PM
C-AREVALO's Avatar
C-AREVALO
Yez sir its a 351w and the donor truck is a f 250 but the motor mount perches are just welded pieces of railing or something like that lol. Well I got some perches today but they look like one shorter than the other one. And regarding transmissions I want an overdrive unit IF possible but a manual I dont mind either. As for as my truck info its a 1979 f 100 with a 351-400m that I want to take off to replace with the windsor. And thanks for the info sir...
Old Apr 18, 2014 | 05:50 PM
HIO Silver's Avatar
HIO Silver
OK. thanks.
For an automatic, consider the AOD, AODE, or 4R70W. Here's a really good article on sourcing and swapping in an AOD: Ford AOD Overdrive Transmission | Hemmings Motor News
For manual trans a T5z, a TKO, or if at all inclined to keep the 351M/400 - a ZF5.
Old Apr 18, 2014 | 08:29 PM
C-AREVALO's Avatar
C-AREVALO
Thanks for the link it has great info once again thanks...
Old Apr 18, 2014 | 08:43 PM
ShaneNP123's Avatar
ShaneNP123
Originally Posted by HIO Silver
OK. thanks.
He could run a ZF behind the Windsor as well, but would require converting the truck over to a hydraulic clutch set up.
Big Norm
Sep 8, 2015 12:20 PM
Twisted Light
Jul 27, 2007 07:36 PM
92F150XLT4*4
May 20, 2003 09:31 PM
sandslinger
1978 - 1996 Big Bronco
Sep 19, 2002 07:49 PM
frogger01
Mar 15, 2001 06:08 PM
