clutch fan
Old Apr 12, 2014 | 11:55 PM
brandon.edwards's Avatar
brandon.edwards
clutch fan
Im not sure if my fan clutch has the snow plow package, but if I buy a snow plow package fan clutch, will it fit even though it may not have one from the factory?
Old Apr 13, 2014 | 01:59 PM
m-chan68's Avatar
m-chan68
Yes it will fit. There is virtually no difference in the external appearance of the part itself between the two, other than the part number. The only difference that I recall, from installing one years back, is the plow package version commands more frequent operation, due I guess to a plow being installed, which obstructs air flow through all the heat exchangers.
Old Apr 13, 2014 | 03:30 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
My fan w/ plow package seems to lock in easier than our other '07 with the standard clutch. Either idling in traffic, using stationary high idle, and during just regular idle the FSS/ fan clutch PID seems to kick up more frequently.
On the highway I've never noticed a difference. But I've never live data stream tracked this, so it's still mostly just my casual observations and not hard fact.
Old Apr 13, 2014 | 04:25 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The HD clutch fan can cause the engine to run hotter at highway speeds.
Plus the fact it runs more which causes a drop in MPG.
Without a plow blocking air flow it's useless on a normal engine.
Josh
Old Apr 13, 2014 | 05:36 PM
69cj's Avatar
69cj
Josh
That's some good info Josh. Thanks, gives the reason not to upgrade.
Old Apr 13, 2014 | 08:48 PM
brandon.edwards
So will the normal fan clutch be good enough when the plow is on in the wonter time?
Old Apr 13, 2014 | 09:30 PM
texastech_diesel
Token Redneck
If it starts overheating, switch them out. If not, leave it.
TSB 07-11-5 DIESEL ENGINE - OVERHEATING WITH A SNOW PLOW INSTALLED ON VEHICLES WITHOUT THE FACTORY INSTALLED SNOW PLOW PACKAGE
FORD: 2003-2008 F-Super Duty
This article supersedes TSB 07-8-4 to update the vehicle model years and engines.
ISSUE:
Some 2003-2008 F-Super Duty vehicles with a diesel engine, that are not equipped with the factory snow plow package, may exhibit an engine overheat condition if a snow plow is installed on the vehicle. The condition typically will occur during normal highway driving. This is due to the snow plow blade disrupting airflow to the engine, causing the cooling fan to stop turning or to spin in reverse.
ACTION:
A new clutch fan (only for snow plow applications) may be installed to correct the condition. Cost of the new clutch fan and its installation is the responsibility of the customer. Refer to Workshop Manual Section 303-03 for removal and installation.
PART NUMBER - PART NAME
4C3Z-8A616-SA (YB-3013) - 6.0L Fan Clutch
8C3Z-8A616-A (YB-3091) - 6.4L Fan Clutch
super01duty
Oct 11, 2017 06:06 AM
brandon.edwards
Mar 15, 2014 11:24 PM
Dyllan78
Jan 17, 2012 07:19 AM
desertt5
Dec 11, 2011 09:33 AM
Unrealo4
Jul 26, 2011 11:54 PM
