dead on the road
Old Apr 10, 2014 | 02:32 PM
99StrokeXLT's Avatar
99StrokeXLT
dead on the road
Truck won't crank has been getting harder to start even with the weather warming up here in new england. I thought it was batteries but jumping it did not seem to make a difference. Unplugged and checked the fuse for the fuel bowl, no luck. Can anyone point to something?
Old Apr 10, 2014 | 02:35 PM
Pikachu's Avatar
Pikachu
I would check all connections, both hot and ground and if those check out, I'd suspect the starter. Are you stuck somewhere now?
Old Apr 10, 2014 | 02:36 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Maybe starter, starter solenoid. Have someone turn the key while you check the voltage going to starter.
Old Apr 10, 2014 | 02:41 PM
99StrokeXLT
b
Terminals are good replaced batteries within the last year. Starter solenoid clicks no crank. Stuck outside the house were working on
Old Apr 10, 2014 | 02:46 PM
Pikachu's Avatar
Pikachu
You might try smacking the starter a couple times with a mallet. Sometimes that will get another start or two out of one that's on it's way out. You aren't in Southeastern CT are you?
Old Apr 10, 2014 | 02:49 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Have you checked voltage going to starter? Just because it clicks doesn't mean it's good (no sarcasm ment)
Old Apr 10, 2014 | 03:06 PM
99StrokeXLT
Banged on the starter no dice. Don't have a voltage meter here but tried to start while jumping twice. I'm in lexington mass.
Old Apr 10, 2014 | 03:07 PM
99StrokeXLT
Tow truck is on the way
Old Apr 10, 2014 | 03:15 PM
Pikachu's Avatar
Pikachu
Well that kind of sucks, but at least you're not on the side of the interstate. Been there, done that
Old Apr 10, 2014 | 03:28 PM
The Brad's Avatar
The Brad
Can you try shorting the lugs on the solenoid on the passenger fender? There's a rubber cap over the batt+. You can short it with a pair of pliers.
Old Apr 10, 2014 | 04:01 PM
Jesser02EX's Avatar
Jesser02EX
Yes I would try and jump the starter to see if it will turn over the truck. That will eliminate it from the mix. Then you can track back to the fuse panel and the key..
Old Apr 10, 2014 | 04:21 PM
The Brad's Avatar
The Brad
I had the same problem a while back and even though batt terminals looked good, my +cable ends were stretched from years of over torquing them on the batt. With the nuts tight, I could still spin the cable on the batt post. While troubleshooting, I had voltage at the starter, but there wasn't enough current to turn it over.
Old Apr 11, 2014 | 02:25 AM
BigAlsPSD's Avatar
BigAlsPSD
Sounds like you at least got it somewhere but now, but with it not cranking I would have tried Neutral or wiggling the shifter as the linkage can become loose and not actually indicate P or N.
02GrayPowerStroke
1997 - 2003 F150
Jul 11, 2015 10:17 PM
MorrisCtyFord
Jan 20, 2013 01:15 PM
cjspack
Feb 23, 2010 07:19 PM
IDPisan
Oct 6, 2009 01:43 PM
KevinC.
Feb 22, 2009 08:59 AM
