7.3 wont start
Old Apr 8, 2014 | 01:18 PM
Jon Bradshaw's Avatar
Jon Bradshaw
7.3 wont start
checked codes and had low voltage injector #1 changed the injector got same error. was given the idm harness connector diagram. injector 1 & 7 where low on the ohms test 2.4 and 2.6 rest at 2.9 checked ground circuit both open then checked the injector ground shield left bank short right bank open . question # one are injector 1 & 7 ok. # 2 the ground shied pin was pin 18 on the idm connector tried to trace it back and no pin 18 on the main wire harness. where is the ground shield
thanks jon
Old Apr 9, 2014 | 12:01 AM
Bonanza35's Avatar
Bonanza35
What makes you think its injectors because it won't start? You check the fuel heater fuse? Did you change the CPS? What's your ICP pressure? It's not usually injectors if it won't start. Has it been getting harder to start over time? How cold has it been, is your glow plugs or relay working correctly? We need more information.
Old Apr 9, 2014 | 09:08 AM
BillyBob69's Avatar
BillyBob69
What Bonanza said.
Do you have the wait to start light?
Puffs of white smoke from the exhaust when trying to start?
Does the tach needle move at all when trying to start?
Is the HPOP full? Engine oil level full?
Before you go digging deep into wiring and injectors, lets check some of the basics first. Could be a simple fix.
Old Apr 9, 2014 | 07:24 PM
Jon Bradshaw
to the above error code was for injector one. grounding shield wire had rubbed a spot on two of the injector wire. repaired nowworking
Old Apr 9, 2014 | 09:36 PM
BillyBob69's Avatar
BillyBob69
Glad you got it fixed. Nice when it's an easy fix and inexpensive.
jchev2004
Jan 23, 2024 11:26 AM
Camh65
Bronco II
Jul 4, 2018 11:41 PM
NoLuckChuck
Nov 11, 2014 02:02 PM
CowboyUp1387
May 21, 2009 10:18 AM
gary2208
Mar 25, 2008 10:12 PM
