No Injector Buzz, No Start
It won't start and when I turn the key the injectors will not cycle and there is no Buzz.
There aren't any codes in the computer.
I've run the injector cycle test from my Snap On test box and it fails.
I've gone through the no Start check list and the truck passes except for the KOEO Injector Buzz test.
Even though the FICM passes all tests and has all the proper voltages I swapped it with a FICM from a running truck and still there is no start, no injector Buzz, and it fails the injector test.
What conditions have to be met for the KOEO Injector Buzz test to run?
Open or short injector circuit <---------
Injector connector - lower likelihood as each bank is "bundled" on the harness/FICM connector and they generally fail "per bank"
Injector solenoid
FICM power -- appears to be ruled out by scan
FICM ground circuit <---------
FICM -- appears to be ruled out by your swapping
Data List (in addition to CMP, CKP inactives/faults, IPR output ckt fault, FICM enable fault (possible PCM -- EVEN WITH NO DTCs), PARTIALLY CLOGGED SCREENS:
11.5V MIN IGNITION
FICMLPWR 8V Cranking
FICMVPWR 11.5V MIN IGNTION ON
FICMMPWR 45V MIN
RPM 100 MIN <---------
ICP 500PSI
ICP_V .80V MIN
IPR 45V MIN
IPR Greater than 60%
ICP 1500PSI MIN <---------
Fuel PW 500us - 2ms
FICM SYNC Yes/No
The cranking rpm goes well past 120 rpm on a cold day and I have seen ICP pressure in the 1900 range.
I think the key symptom is the Pre-Cycle test does not run when KOEO and when I command the injector test with my test box it fails.
I agree with you that is appears to be Electrical or Command related.
Also, the injectors don't cycle when the key is turned on and the injector cycle test fails. This symptom does not have anything to do with minimum cranking RPM.
I believe I've eliminated the wiring harness as the root cause and I'm going to swap out an injector to see if the results of the injector cycle test change.
Whoa nelly ---She's cranking @ 230 rpm >>> ??? <<<
Geronimo ----Those cylinders can't be sealing if she's pushing that number......................
https://www.ford-trucks.com/forums/1...e-6-0-a-2.html
Being in Texas though, I can't relate to -10 degrees!! I agree that 230 rpm seems high at that temp for even a 6.4L starter.
I did run a compression test as well with all the glow plugs out and the compression ranged from 372 - 381 which is within spec. I wanted to confirm that its not a head gasket or valve train issue.
The weather is going to improve greatly this weekend and I'm going to swap an injector with a new one to see if it passes the injector cycle test.
The non cranking fuel pressure is over 45 PSI but doesn't change when you are cranking the engine.
This and the failed injector cycle test leads me to believe that the injectors have failed.
