Question about posting.
Old Apr 9, 2014 | 06:16 PM
Walleye Hunter's Avatar
Walleye Hunter
As I read and learn and have questions of my own I have one that I am not sure of. When I see a thread that discusses an issue similar to one I have should I post my issue/question on that thread or should I start another? I am not worried about posting on another thread but then I don't want to hijack someone else either.
Thanks,
Mark
Old Apr 9, 2014 | 06:50 PM
F350-6's Avatar
F350-6
It kind of depends. If you have just a general question you need some clarification on, jumping in is fine. If you need help diagnosing and it's likely to be a question and answer session that requires several steps or responses, then it's best to start your own thread.
If it's a process you need to run through, you want to know for sure when someone asks, did you check XYZ if they're referring to you, or the original poster in the thread.
If your question is just, where is the XYZ sensor, or what does it do, then no harm in jumping in on someone else's thread.
Old Apr 10, 2014 | 07:09 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by F350-6
It kind of depends. If you have just a general question you need some clarification on, jumping in is fine. If you need help diagnosing and it's likely to be a question and answer session that requires several steps or responses, then it's best to start your own thread. If it's a process you need to run through, you want to know for sure when someone asks, did you check XYZ if they're referring to you, or the original poster in the thread. If your question is just, where is the XYZ sensor, or what does it do, then no harm in jumping in on someone else's thread.
^^^ what he said.
husker
Kansas Chapter
363
Oct 7, 2024 02:21 PM
timmyboy76
662
Feb 17, 2021 03:31 PM
76f350spercamprspeal
General Automotive Discussion
Jun 22, 2009 11:38 PM
