5.8 Injector pulse
Old Mar 23, 2008 | 09:57 PM
gary2208's Avatar
gary2208
Question 5.8 Injector pulse
Injectors will not pulse. Any ideas ?
Old Mar 23, 2008 | 10:17 PM
Conanski's Avatar
Conanski
Start by pulling the codes.. find and ground the single wire attached to the EEC Test plug harness under the hood(for all years except the '96 F150), and write down the sequences as they flash on the check engine light after you turn the ignition on.
Old Mar 25, 2008 | 09:53 PM
gary2208's Avatar
gary2208
Thanks for reply
No codes. I installed the FMS MAF kit, but no help. No pulse on the noid light. I have not a clue.
Thanks for the help
Gary
Old Mar 25, 2008 | 10:04 PM
frederic's Avatar
frederic
The EEC connects the injectors to ground, and the other "leg" of the injectors should be given "hot" at all times the key is in the "run" or "start" positions. Check fuse, fuse link, EEC relay, and things of that nature.
Injectors not firing *should* give a code but unfortunately that's not always the case depending what is wrong. I would start by checking for voltage on the injector connectors, looking for 12-14V on one wire (with the injector connector unplugged) and see what you get and troubleshoot from there.
Old Mar 25, 2008 | 10:12 PM
gary2208's Avatar
gary2208
Thanks for your help. I will reply soon
Conanski's Avatar
Conanski
We'll need more information then. If the motor has never run since the MAF conversion then no.. there will be no codes. What year are we talking? What motor? Did it run before the swap? As much background as you can think of...
rbspear
16
Jun 30, 2015 10:47 PM
c4jlca
Jan 13, 2013 03:32 PM
clman
Nov 16, 2012 12:49 PM
sesrgulledge
Mar 23, 2010 11:01 PM
