I won't bore you with all of the details, but, I helped a good friend of mine put together his 350 cu. in. Pontiac engine, back in the early '70s.
When we finished, and were cleaning up, we discovered ONE wristpin keeper on the bench!!!!!!!
Yes, we disassembled that engine. We got lucky.
Cylinder #2 had one wristpin keeper missing.
Just did that last weekend. Replace water pump and timing belt o. 99 Honda civic. Got down and realised there was 2 bolts left in the jar. They were from the water pump. And if you know civics that's alot of of dissembling everything agian haha.
You need a vacuum adaptor to get the air out of the system.
You put the adaptor cap on and them place the system under
a vacuum to expand any air and get it to move. You then
let the vacuum off and check the fill level and repeat till
you no longer get a drop in the fill level.
Here is a Youtube how to from srmastertech.
It on a diesel but the same filling system works on
both diesel and gas. he start the filling process
at 4:12 into the video.
at 4:12 into the video. 6 4 Liter Ford Powerstroke Rad Vac Refilling - YouTube
Sean
thanks, im gonna have to see if i can rent that tool any where
It's pretty easy to tell if there's air in the system preventing circulation. Does the upper hose feel firm like it's under pressure? Is the air being blown through the radiator warm or cool?
I think it's a thermostat issue. Someone on the Excursion forum installed the thermostat o-ring on the wrong side causing some strange issues, so that could be something to look for. Is the seal underneath or on top of the thermostat?
the o ring is ablove the thermostat, on the thermo housing the upper hose just feels warm and its not that hard to squieze it. i think there is a little pressure in there, i can hear a release when taking the rad cap off
