need input
Old Apr 7, 2014 | 04:45 PM
doc62's Avatar
doc62
need input
O.K., searched this site for an answer, sorry,maybe I missed it. Here's my problem. I have a '94 F250 2wd 7.3 IDI,auto. 355000 miles. Replaced injectors and return lines and it ran like a new truck for about 2 weeks.Wife was headed to the store when she heard a loud pop and smelled fuel,started running like crap at that point. The return cap on #7 injector was cracked and spraying fuel out, plus pushing fuel out of the rear tank. It was running rough and would idle with the rpm's up, but let off and she would stall.Any ideas would be appreciated.
Old Apr 7, 2014 | 06:36 PM
bashby's Avatar
bashby
Obviously you need to replace the broken cap. Did you replace them with the return lines? I've seen some some kits that come with the caps but have heard they aren't very high quality compared to oem. It sounds like you could have a problem with the tank selector system returning to the wrong tank... Maybe it's causing an overpressuring of the return system.
Old Apr 8, 2014 | 08:12 AM
doc62's Avatar
doc62
Yep,it was the new one that cracked,had to put the old back on.Will try tank selector switch,thanks.
Old Apr 8, 2014 | 10:15 AM
hairyboxnoogle's Avatar
hairyboxnoogle
So it made an audible pop sound, and gushing fuel at the fuel tank? Id say the injector came apart / catastrophic failure allowing cylinder pressure into the return line. Pull the injector and take a looksy at it.
Old Apr 8, 2014 | 12:07 PM
doc62's Avatar
doc62
Thanks,will do it. I guess a brand new injector can still fail.
Old Apr 8, 2014 | 03:58 PM
hairyboxnoogle
From my reading, its more common than you would think.
Old Apr 8, 2014 | 09:11 PM
Macrobb's Avatar
Macrobb
Could the return line be clogged, or the selector valve fail?
Remember, our IPs work on pressure differential... if your return line got blocked somehow, the pressure would equalize and the IP wouldn't run well at all.
Also, pressurized return lines might explain a broken cap, but I'd usually expect the o-rings to fail first.
Injector wise, remember: the amount of fuel going into it /total/ is very small. The entire output of the IP for one cyl could easily go into the cap and return to the tank -- sure the pressure is at 2Kpsi when it's injected... but if you give it anywhere to go, that pressure will be near zero. It's only the massive spring in the injector keeping it closed that allows the pressure to rise.
3000gtman
Feb 2, 2017 10:14 PM
mark's1984
May 22, 2016 01:53 PM
BigBlue92
Sep 7, 2011 10:20 PM
6.9lXLTf250
Nov 26, 2010 09:43 PM
ncfirefighter46
Apr 11, 2006 06:55 AM
