Question on guage cluster interchangeability
Old 04-06-2014, 01:05 AM
Bluethunder3320's Avatar
Bluethunder3320
Bluethunder3320 is offline
I have a 94 f150 300-6 Xl with no tach. Slowly adding XLT parts.
I understand now that a 92-93, 94-95, and 96-97HD clusters are only interchangeable because of the addition of air bags and changes in the circuit boards.
I am at the stafford ct swap meet right now and see a lot of diesel clusters. Of course the diesel and gas tachs are different, but I have a 93 cluster with tach that I'm thinking might fit on the diesel cluster.
So what I'm trying to do is get a 94-95 diesel cluster and switch out the tach with the gas one from the 93 cluster I have, and the PSOM from my 94 which is in my truck. Does anyone see problems with this or think it would work?
Old 04-06-2014, 08:12 AM
Eddiec1564's Avatar
Eddiec1564
Eddiec1564 is offline
That should work, just compare the back of the clusters to make sure there are no differences between Diesel and gas clusters!
IF you have a 93 gas cluster allready, you can adapt it into the 94's harness, its a few pins that need to be swapped between the plugs.
There is a few threads on how to do this right here, just have to search for "tach cluster swap"
Kuhlvette
Electrical Systems/Wiring
07-31-2019 02:16 PM
12valveEx
08-02-2015 08:07 PM
eagle275
06-19-2015 10:31 AM
Romel77
63
06-10-2015 10:15 AM
sncstealth
03-02-2010 10:28 PM
Quick Reply: Question on guage cluster interchangeability
