Bottom half standpipe stayed in
Old Apr 5, 2014 | 03:23 PM
Shelbynut's Avatar
Shelbynut
I'm changing standpipes and plugs. When I tried to take drivers side out, the bottom half stayed in! Is this normal for factory pipes? If so, how do I get the rest out? The videos I can find show it all coming out at once. I gotta get this thing running by Monday AM.
Thanks for the help,
Dave
Old Apr 5, 2014 | 03:53 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Originally Posted by Shelbynut
I'm changing standpipes and plugs. When I tried to take drivers side out, the bottom half stayed in! Is this normal for factory pipes? If so, how do I get the rest out? The videos I can find show it all coming out at once. I gotta get this thing running by Monday AM. Thanks for the help, Dave
I believe you will have to remove the oil rail to get the low part out.
Old Apr 5, 2014 | 04:09 PM
mustang_309's Avatar
mustang_309
Dave
Try wrapping the bottom of the upper piece with some electrical tape and reinstall it the take it back out and see if the lower piece comes out with it
Old Apr 5, 2014 | 04:32 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Or just replace the upper part and leave the bottom.
Josh
Old Apr 5, 2014 | 04:50 PM
jdw1's Avatar
jdw1
Josh
That's what my mechanic said the night I called him at home when I was a doing mine.
Old Apr 5, 2014 | 04:53 PM
mustang_309
Josh
That's the best idea.
Old Apr 5, 2014 | 05:05 PM
Shelbynut's Avatar
Shelbynut
The new one doesn't seem to come apart. I think the bottom o'ring is leaking on the passenger side. When pressure testing the gurgling sounded down low. How big a can of worms will I open if I try to pull the oil rail off? Will I need more parts? The e tape didn't work. I'm gonna try finding a wood dowel and taper the end and see if that works. Some C-4 is starting to sound good!
Dave
Old Apr 5, 2014 | 05:26 PM
Bullitt390's Avatar
Bullitt390
Dave
While it's possible that particular o-ring is leaking, in the grande scheme of areas that leak, that is the least likely.
Dummy Plugs
STC
Oil Rail Nipple o-rings
Upper Standpipe
Oil Rail test port plug
But, the easiest is to remove the oil rail and pull it out with pliers. Since you're diehard on replacing it just jam a screwdriver into it and pull up.
Josh
Old Apr 5, 2014 | 05:54 PM
Shelbynut's Avatar
Shelbynut
Just looked closer and had a sick thought. The o ring that seals the bottom of the rail is still in - only one came out. Does that mean I have a spring and check valve floating around in the rail or didn't the original one have it. I'm really getting tired of this thing. It has been one thing after another since I got it two years ago. What a PITA to work on. Give me a '60s carb gasser and 4 speed any day!
Dave
Old Apr 5, 2014 | 06:28 PM
mustang_309
Dave
Can you take a photo and show us exactly what came out? You can email it to me and I can post it if you like. just PM me and I will give you my email.
Old Apr 5, 2014 | 06:29 PM
Bullitt390's Avatar
Bullitt390
You cannot access the check valve.
Josh
Old Apr 5, 2014 | 07:08 PM
04badford's Avatar
04badford
Stand Pipe & Dummy Plug Set, Ford 6.0L Diesel
witch part is stuck in ?
Old Apr 5, 2014 | 07:56 PM
Shelbynut's Avatar
Shelbynut
All that came out was the threads and about 1 1/4" below - the part with the holes. The bottom 2 o rings stayed in. I can spin it with the screwdriver but cant get it to grab enough to pull it. Was gonna try an easy out but the ones I have are too short.
Dave
Old Apr 5, 2014 | 08:28 PM
04badford's Avatar
04badford
Try a pair of needle nose or snap ring pliers that expand out ward.
Old Apr 5, 2014 | 08:42 PM
mustang_309
Dave
Here is a photo of what came out, Name:  20140405_201051_1_resized.jpg
