Need to remove some coolant
Old Apr 5, 2014 | 09:22 AM
KDAVID1's Avatar
KDAVID1
Is the best way to remove some coolant to just use a baster and suck out of the degas bottle? Looks like the dealer topped it off so its on the max line now.
Old Apr 5, 2014 | 09:33 AM
r2millers's Avatar
r2millers
Yep but the max line shouldn't be an issue. That's what it's there for. Sounds like the dealer do the right thing.
Old Apr 5, 2014 | 09:39 AM
bubba_78363's Avatar
bubba_78363
The petcock for the radiator is on the lower left side. IIRC it takes a 3/4" socket to loosen if its OEM. Be careful they have a tendency to break if you put too much umph behind them. Just crack it open and drain while watching level in degas bottle
Matt
Old Apr 5, 2014 | 09:49 AM
jswartz84's Avatar
jswartz84
There was a recall and an added sticker to the degas bottle that stated the minimum line would be the new max. This was to prevent puking.
Old Apr 5, 2014 | 09:55 AM
KDAVID1's Avatar
KDAVID1
Matt
Thanks that will probably be the easiest way.
Old Apr 5, 2014 | 11:09 AM
npccpartsman's Avatar
npccpartsman
Sounds like someone that didn't have a clue what they were doing was messing with your truck.
The petcock is by far the easiest way to drain to the correct level. I maintain mine at 1/2" BELOW the minimum line and have for YEARS with no issues.
Old Apr 5, 2014 | 11:18 AM
KDAVID1's Avatar
KDAVID1
Yep-think they meant well but you know. 1/2 is exactly where I want mine.
Old Apr 5, 2014 | 12:13 PM
KDAVID1's Avatar
KDAVID1
Got it down. Thanks for the info on the drain.
tracyclifton
Apr 3, 2015 09:47 PM
Mcrafty1
Sep 21, 2013 05:37 PM
GeneLaw1
Jan 31, 2012 09:23 PM
DALEDIESEL
May 4, 2007 08:42 PM
