Installing ARP studs w Cab on
Old Apr 4, 2014 | 11:01 PM
RideDiesel88's Avatar
RideDiesel88
It seems to me the main reason people lift the cab is to get the rear drivers side head bolt out easier. Well that's what I've heard but I was able to get it out without lifting the cab. Am I going to be able to get a stud in without lifting the cab?
Old Apr 4, 2014 | 11:31 PM
Randy777's Avatar
Randy777
Diesel Power magazine had an article a while back on doing the studs with the cab on. If I remember correctly they dented the inside of the engine compartment a little bit to give you more room.
Old Apr 4, 2014 | 11:40 PM
jswartz84's Avatar
jswartz84
On an 03 I helped with, we had trouble with the HVAC box on the passenger side. We ended up loosening the motor mounts and dropping it down abould 1.5 inches and it worked perfect. You can install stud with the cab on.
Old Apr 5, 2014 | 12:04 AM
9228.bobcat's Avatar
9228.bobcat
Yea I have done a few with cab on. Like mentioned either loosen the motor mounts, dent firewall or remove hvac box or split it.
Old Apr 5, 2014 | 07:34 AM
AKPOWERSTROKE's Avatar
AKPOWERSTROKE
This is very simple. Insert the driver rear and the passenger lower 3 to be safe prior to install. Wrap a rubber band around them closest to where the bolt goes into the head twice and then wrap around a valve spring nearby.
This will prevent them from dropping into the head while maintaining clearance during head install.
(IMPORTANT NOTE. MAKE SURE THE HEAD BOLTS DO NOT PROTRUDE OUT THE BOTTOM OF THE HEAD OR YOU WILL HIT THE HEAD GASKET AND DAMAGE IT.)
I have done this method 4 times with zero issues. Hoep this helps
Old Apr 5, 2014 | 08:06 AM
cheezit's Avatar
cheezit
Thats how we did them in cab
Old Apr 5, 2014 | 09:15 AM
KDAVID1's Avatar
KDAVID1
So you're saying slide those studs in the head then drop on the block? Would you have to do any of the denting of engine bay or moving that box?
Old Apr 5, 2014 | 09:53 AM
AKPOWERSTROKE
You actually have two options.
A: Dent driver firewall just enough to facilitate removal and installation or
B: Purchase an OTC offset torque adapter that will allow access to the bolt without denting firewall.
Snap on Link Snap On SRD35 $58
Amazon Link
CTA Tools 9258 CTA Tools 9258
$29
As far as the box is concerned. I just removed the inner cover on the A/C box. That allowed enough clearance to remove and intall heads. Keep in mind I did not remove the heads with the exhaust manifold attached. I am pretty sure it will work either way.
Old Apr 5, 2014 | 09:57 AM
KDAVID1's Avatar
KDAVID1
Well 58 bucks is worth the price not to have to do a bunch of banging
Old Apr 5, 2014 | 10:03 AM
AKPOWERSTROKE
Definitely. I didn't know they made this before I did mine. The job is not to painful?
Old Apr 5, 2014 | 11:54 AM
cheezit's Avatar
cheezit
You dont even need that tool. A quality 24" torque wrench and a 12 point shallow scoket.
Old Apr 5, 2014 | 12:27 PM
BLADE35's Avatar
BLADE35
there ya Go ^^
You could do it in your sleep Moe LOL
Just Like Hanging Doors for me In 3 Weeks I set Almost 100 Doors and installed roughly 3400 Feet of Baseboard Be Close to 1 Mile of baseboard Next Friday LOL
All in about 4 Week
Old Apr 5, 2014 | 12:37 PM
RideDiesel88
Cool thanks to all the replys
Old Apr 5, 2014 | 01:19 PM
cheezit's Avatar
cheezit
Originally Posted by BLADE35
there ya Go ^^
Never learned how to hang doors . I really need to, ive got one I need to replace.... stupid dogs
Old Apr 5, 2014 | 01:25 PM
BLADE35's Avatar
BLADE35
they killed the Bottom
what door is it Moe??
Interior or Exterior Door??
Peteg5
23
Mar 14, 2011 10:07 AM
sidwaz
Jan 16, 2009 09:16 PM
leonharu
Feb 24, 2008 07:34 PM
inline6 Red Neck
Jun 8, 2006 10:39 PM
Brno 7x57
Paint & Bodywork
Jun 10, 2002 08:55 AM
