Cab Mounts
Old Jun 8, 2006 | 04:32 PM
inline6 Red Neck's Avatar
inline6 Red Neck
Red face Cab Mounts
i going to need to put new cab floor monts on my 1977 f150 do i have to pull the cab off or is there any other way to do it ?
Old Jun 8, 2006 | 04:47 PM
highboy1975's Avatar
highboy1975
no, just go from the bottom, depends on how good you are at getting things into tight spaces. pulling the cab would make everything much more accessible, but isn't necessary unless you feel it is.
Old Jun 8, 2006 | 10:16 PM
inline6 Red Neck
thanks a lot
Old Jun 8, 2006 | 10:39 PM
bucks77ford's Avatar
bucks77ford
Thumbs up
If you can spare some more time on your project, I would suggest taking the cab off. I think you would be much happier in the long run. You can get a good look at everything and not have to worry about fitting your tools into the tight places. You would be able to do a better job also. Whatever you decide, good luck.
