ignition switch problems 89 E150
Old Apr 4, 2014 | 01:03 AM
VanManWife's Avatar
VanManWife
We are having ignition switch problems with our 89 Econoline 150 V8 5.0 Automatic Transmission. We just replaced the ignition switch, ignition lock and key, & starter solenoid. However, we've only been able to get it started once by bypassing the starter solenoid. We don't feel like we have the starter switch adjusted properly due to everything else that we've read. Any ideas?
Old Apr 4, 2014 | 09:07 AM
subford's Avatar
subford
I take it is not cranking when you turn the key.
If so check the ST wire where it leaves the Ignition switch plug for power when you turn the key. If you have power there then I would check the neutral safety switch on the side of the transmission.
What transmission do you have?
Joshua Heath Rice
Sep 4, 2014 01:33 PM
Rayray1102
Sep 8, 2009 06:42 PM
DKF Photo
Mar 2, 2004 12:04 AM
bajabronco
Electrical Systems/Wiring
Sep 18, 2003 07:53 PM
BBiffle
Jul 22, 2003 11:19 PM
