GP compression test adapter
Old Apr 6, 2014 | 10:23 AM
  #31
Dan V's Avatar
Dan V
Guys....just got done doing a compression test. I have the M10 ORB and grease whip.......THAT'S THE WAY TO GO!!!!
R&D....over....results in the other post.
Old Apr 6, 2014 | 01:51 PM
  #32
BigAlsPSD's Avatar
BigAlsPSD
You do use a deep socket but just to loosen it, you can't take out the gp without hitting the rockers using strickly a socket, that's why many use a piece of hose. It would work with the center reduced though.
Old Apr 9, 2014 | 08:13 AM
  #33
Pikachu's Avatar
Pikachu
Finally remembered to measure. From the tip of the pin on the glow plug to the socket the push rod sits in is 1.5" and to the top edge of the rocker is 2.25". Those are close approximations, and are with the valve closed.
Old Apr 9, 2014 | 08:37 AM
  #34
Dan V's Avatar
Dan V
I tries getting the piece I made into the GP hole...I didn't feel like fighting it in....the extra length caused it to contact the rocker before it dropped into the hole. The extra length was the reason.
man-o-war
19
Mar 12, 2021 10:36 AM
fscarrow
Aug 7, 2014 10:11 AM
scotttahoe
Mar 28, 2014 08:02 PM
hugger94
Sep 17, 2012 08:16 PM
rigoberto
19
Feb 5, 2009 09:33 PM
