GP compression test adapter
Old Apr 3, 2014 | 05:06 PM
Firefighter 1406's Avatar
Firefighter 1406
Ya I would be interested in a price also.
Old Apr 3, 2014 | 05:35 PM
Dan V's Avatar
Dan V
I just gonna hand'em out like door prizes.
Old Apr 3, 2014 | 05:45 PM
Bonanza35's Avatar
Bonanza35
Dan V, your the man. It will be deeply appreciated, Rep's sent.
Old Apr 5, 2014 | 01:09 PM
Dan V's Avatar
Dan V
The R&D piece
For some reason I had thought a piece of 3/8" steel hex would make this. But no, it needs to be 7/16". I started this with a piece of 5/8" round brass. Brass because it's highly machinable and forgiving of programing mistakes. I bought it over to a Bridgeport and milled the flats on. Future parts will be from hex though. It's 5" OAL...I see if it's long enough, or too long on Sunday.
Still looking for mooch a 12-36 plug tap for the schrader valve. If I have to buy one I will...but it's like $30 or so.
Old Apr 5, 2014 | 01:16 PM
Jesser02EX's Avatar
Jesser02EX
That looks great, thanks for all the work
Old Apr 5, 2014 | 01:26 PM
Pikachu's Avatar
Pikachu
Dan, don't forget it needs to be high enough for the quick connect to clear the rocker arm at the cam's highest lift point. I can measure on Monday if you need the height above the tip of the pin on the glow plug.
Old Apr 5, 2014 | 01:45 PM
Dan V's Avatar
Dan V
That would be good. This rev is 1 1/4" longer than a GP, from seat to tip of elec connector.
Old Apr 5, 2014 | 01:56 PM
Pikachu's Avatar
Pikachu
I set a calendar reminder, and I'll post it Monday morning.
Old Apr 5, 2014 | 01:58 PM
scotttahoe's Avatar
scotttahoe
Nice looking good!
Old Apr 5, 2014 | 07:43 PM
Firefighter 1406
Dan,
Thank you so much for the work. This is gonna be a really awesome tool for the tool box. Thank you for all your hard work. So what are you thinking price wise?
Tried to rep ya, but they got me locked down.
Old Apr 5, 2014 | 08:12 PM
Bonanza35's Avatar
Bonanza35
Why not just make it screw onto the wipe? I think that would be easier and it would get around the rockers better.
Old Apr 5, 2014 | 09:17 PM
BigAlsPSD's Avatar
BigAlsPSD
I actually did a compression test today, with my small fitting and whip. Still like the whip due to the flexibility, not sure a straight fitting will work unless you narrow it in the center to allow room for the rockers, and then your hex atop that. But I like that you are trying offer an alternative.
What height would you like? I have 3 motors out of trucks sitting here...
It's 3 1/2" minimum, then plus whatever the lift of the lifters is, from the seat of the head that the glow plug seats to the top of the rocker arm.
Old Apr 5, 2014 | 09:24 PM
  #28
BigAlsPSD's Avatar
BigAlsPSD
If that's the way you want to do it, like I do, Parker #M10-1/8F8OHGS fitting will accomplish this, then you just need a 1/8" barrel for the other end of the whip to thread the quick connect into.
Old Apr 6, 2014 | 06:42 AM
  #29
Dan V's Avatar
Dan V
Well.....there is a reason I didn't purchase a bar of stock and saw it up into blanks. The comment about a reduced center section opened my eyes.
Just so we're clear...this isn't hard work. This is something that you do while you're changing from one production part to the next....and it's a heck'of'alot more fun than making the same part you've been making for the last 15 years.
It very well may be the "best" solution is the M10 ORB fitting and the grease whip....I'll know today. The Ford diesel adapter in the small HF kit is for IDI....and it won't seal properly on the newer 7.3. Maybe my longer adapter with a 1/8 MPT, then the "barrel" to a grease whip. I don't have a 1/8" MPT die, so I'd have to program a tool path to single point that thread....And I just didn't want to develop one.
I would just think a longer piece "should" work..after all the GP goes in there and you have to use a deep socket on an extension to get the GP out.
Old Apr 6, 2014 | 07:06 AM
  #30
Pikachu's Avatar
Pikachu
That was in the back of my mind too. I know the glow plug port is at a slight angle, I just don't know how far from its center line it would intersect the rocker arm.
