6.5" width wheel?
Old Mar 30, 2014 | 10:33 PM
-mywheels-'s Avatar
-mywheels-
6.5" width wheel?
I'm looking for a 8x6.5 wheel in 16" and 6.5 " wide to fit my 1977 f250 4x4. Does anyone have a source for these? My tires recommend a 6.5" width.
Old Mar 30, 2014 | 11:43 PM
Pickupmanx2's Avatar
Pickupmanx2
You can go with 6" or 7", you don't have to be exact,,, I have run 235/85/16's on 16x10's and my 02 Dually when I bought it had 315/75/16's on factory 16x6 rims...and it now has 285/75/16's on them.
What size tires will you be running?
Old Mar 31, 2014 | 12:38 AM
-mywheels-'s Avatar
-mywheels-
Measuring with a tape, they are 34x9x16. Tire says something like "6.5" required wheel width". You sure about running them on a 7"?
Old Mar 31, 2014 | 02:25 AM
trozei's Avatar
trozei
You've obviously never entered the realm of Euro/Jap stance.
Exhibit A: Stretch.
I think your tire will be okay on a rim that is half an inch too wide.
Old Mar 31, 2014 | 11:26 AM
royster69's Avatar
royster69
As the others have stated:
No worries about 1/2"...in either direction.
All manufacturers will state a "recommended" or "approved" range of rim sizes for each given tire size. For example, Toyo says that their Open Country A/T tire in a LT235/85R16 can be run on rims ranging from 6" to 7.5"...with 6.5" being the "measured" rim size...the one they base all of their specs and dimensions on. The industry rule of thumb is that for every 1/2" change in rim width, the tire's section width will correspondingly change by approximately 2/10".
So, you have wiggle room...no problem running slightly smaller or slightly larger rims/wheels. Thankfully, Ford made millions of 16x7 rims for these trucks...and 16x6, too, I believe. Shouldn't be any problem finding a set. As a matter of fact, your truck is probably riding on a set right now...no?
Old Mar 31, 2014 | 12:55 PM
-mywheels-'s Avatar
-mywheels-
No. It's riding on a set of slotted aluminum rims. None of my trucks came with factory rims. My new tires will be for winter, so a set of factory steel rims in black will look nice. Thanks for your help everyone.
Old Apr 1, 2014 | 03:25 PM
royster69's Avatar
royster69
It should be fairly easy to find factory Ford rims...8 on 6.5...16" diameter and 7" wide. So many trucks came with these right up until the late '90s...they're littering the junk yards! They still put them on the 1 ton E-series vans, I believe!
I found a brand new, factory set, black, for $35/rim...which I thought was pretty good for new rims! Otherwise, find a set in a junk yard or someone's back yard...clean 'em up and paint them black. Look for the "Accuride" name stamped in the rim...tells you that they're factory steel rims.
Old Apr 1, 2014 | 03:39 PM
-mywheels-'s Avatar
-mywheels-
Thanks for the tip!
Old Apr 1, 2014 | 04:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
They still put them on the 3/4 ton (E250) & 1 ton E350 vans aka Econolines.
If you look in Ford truck parts catalogs, you will not find any steel wheels that are 7" wide.
This is because Ford measures wheels across from the inside flanges, not across from the outer lips.
F250/350's went to metric wheels in 1999, but no Econoline of any year has metric wheels.
16" 8 lug wheels on a 6.50" bolt circle: 1948/52 F2 - 1953/98 F250 - 1967/98 F350 - 1969/74 E300 - 1975/2014 E250/350.
Old Apr 1, 2014 | 08:51 PM
royster69's Avatar
royster69
Thanks for the clarification on the E-series vehicles, NumberDummy!
Although Ford may not catalogue them as such, I know that Accuride (who made the wheels) puts a stamp on the rim showing "16x7K" just beside the Accuride logo stamp.
Fumagalli, who I believe is the recent (current?) maker of Ford steel rims does the same.
Cheers,
Roy
Jonnyuma
Sep 25, 2017 06:24 PM
David Mchone
Mar 22, 2012 02:17 PM
beefcake
Jan 9, 2011 04:21 PM
speedbug78
Aug 21, 2010 12:09 PM
MIKESANDS
Aug 2, 2006 09:52 PM
